Fiber glass top
- Capt Dick Dean
Fiber glass top
We have a Bahia Mar with a fiber glass top over the helm and engines. The top is 20 yrs old and has crazing in a few spots. And in some places the crazing is such that the gel coat is lifting off. Do I sand this with 220 paper and then fill in the voids?
On another topic .... does white vinegar clean up a full tuna tower?
The boat is under a massive clean up and we need some advice. Thanks!
A/K/A El Gaupo
Dick: On the tower, use Marine Clean from POR15 (www.por15.com) full strength and agitate with a fine Skotchbrite pad. It will take all of the corrosion off. Wash off and coat with CX on a rag. This is the easiest way possible to remove corrosion from aluminum or chromed bronze. Corrosion will melt right off (almost). It is a strong alkaline cleaner, so be sure to wear gloves and wash well afterwards (both you and the tower).
- TailhookTom
Rawleigh:
Will that also remove anodizing? A friend just did a beautiful job on his full tower but the consequences were that the anodizing was removed. His tower was so pitted and so ugly (on a 31 Rampage) that it made sense and came out spectacular. He ended up coating it with Woody Wax and it looks brand new.
Tom
Tom
- Tom
Dick, I use a medium bronze wool saturated with Woody Wax on my metal when the gunga is bad. Otherwise a fine wool or rag with Woody Wax. Last year I did some redneck testing of the Corrosion X and Woody Wax. The Woody Wax did a superior job and lasted a whole lot longer than the red can CX.
I spent a good bit of this past Saturday redoing mine and I've got a lot. Cleaned up nice and easy.
Viva la Presidente!
- Capt Dick Dean
Users browsing this forum: Google [Bot] and 195 guests
