how to get to wire on the fly bridge
Got a 69 FBC, just wondering whats the easiest way to get to the race for the wires going to the fly bridge, i have to run my transducer cable up and want to try and redo my power wiring and other stuff. By buddy said a panel comes off on the starboard side, figure i would ask before i started ripping stuff apart. oh, and is there any way to get behind the panel under the helm.
I never had any luck getting mine apart as it appeared to be faired in in spots with gelcoat. I ran heavy gauge power cables up to a junction block that i epoxied to the inside of the bridge and run everything off of that. It freed up some space and gave me cleaner power. The only other wires are the instrument and transducer wires now.
On my '69 FBC, the outside pillaster covers come right out, and that gives you great access. For the upper helm, on my boat that whole vertical panel below the gauges/wheel, etc., that has 3 access hatches/doors comes out with a few screws, and you have pretty good access to all your wiring.
John F.
John F.
Those little holes that the factory cut into the gunnel where the pillaster lands is the problem. If you are doing a complete rewire I would cut between them and make larger oval openings. If fishing only a new wire, you can't cut them without risking nicking a wire. I also ran heavy braided twine pull cords and tied them off under the bridge and in the engine compartment so it will be easier next time I need to add something.
Users browsing this forum: No registered users and 185 guests
