Need to replace my charger,any better than others?any to stay away from?
txs, Bill G.
battery chargers
Xantrex USED to be the one to buy. I've had zero problems with my True Charge 20 in the 7 years I've had it. But ever since Xantrex bought up Heart, Trace & some other small ones, their reputation has gone way downhill. I've heard many complaints on the True Charge series also. A lot of complaints on Guest also. (I think they might be associated with Rule now). Though initially more expensive, it's been years since I have heard anything negative about Charles.
Al
Al
NITES OFF
1978 B33 FBC
Al
1978 B33 FBC
Al
I used a two bank hand me down ProMariner for three years and was happy. It just stopped working a few months ago. Replaced it with a three bank 20 amp ProMariner. Seems to be fine, although I have added water about once every month or two to the batteries. I am not sure if they should take topping off that much. Usually about 1/4 inch below the plates after several cycles of discharge/charge. Is that normal?
Users browsing this forum: Google [Bot] and 153 guests
