thermostats
Jim M.
thermostats
Post by Jim M. »
Hi, I have 454's fresh water cooled. What temp. thermostat's is recommended.
Thanks, Jim
Harry Babb
Post by Harry Babb »
I like to runuum at 190/195 F........
Harry
Jim M.
Post by Jim M. »
Harry, thanks, I know have a 180 degree thermostat installed, do you use a higher temp.?
Jim
John F.
Post by John F. »
Jim-
I have fw cooled 454s and have 180s. I've never had a problem.
John F.
White Bear
Post by White Bear »
180 thermostat - this time of year with the sea water temperature in the high 50s I get about 170 in the engine, by the end of the month I should be seeing 180+/- as normal until I haul in December.
Harry Babb
I have a 350 freshwater cooled in a 244 Chaparral that I run with a 190 degree thermostat......with no problem.
I prefer the hotter tempt.....I think engines are more efficient at the higher tempts........
Way back in the early 70's I went to a Chrysler Marine Engine class in New Orleans. They told us that seawater cooled engines should not run at more than 140 degrees because the internal corrosion factor accelerates greatly at higher tempts and they recommended 180 degree for the Freshwater cooled engines.
But I just like the higher temps.......
Harry
In Memory Walter K
Post by In Memory Walter K »
I think it's because the higher temperatures crystalize the salt which increases the speed of buildup and blockages. Freshwater cooled engines perform better at 180-190, but not salt water.
Users browsing this forum: No registered users and 255 guests
