I've got a '72 gas B35 and face this ethanol issue. I've been considering switching to Diesel. Since I'm on the fence about it, if my tank is good I may convert sooner. If the tank is bad and needs to be replaced I'll replace it with AL and repower down the road, at which point I consider the tank to have a 5yr life span. The other tank material options are too costly and may be cheaper a few years down the road after more is done.
I've been running E10 since late July, to the tune of about 500gal so far, we ran from Baltimore to Atlantic City and back on it plus a few local trips.
So my question how best to determin if the tank is failing?
So Far I've changed fuel filters twice and noticed a good amount of sediment, i suppose is from the E10 'cleaning' the tank.
My inspection plan:
1) pull all sparkplugs and check for fowling/goo
2) pull off a carb and inspect the inside of the intake
3) If possible pull the inspeciton plate on the tank to get a visual. I'm not sure of this one because of the age of the bolts...
So I'd love to hear any other suggestions on identifying the condition of my tank and whether it needs to be replaced.
br,
JohnD
Tank inspection.
Pull the inspection plate and have a look inside. Soak those bolts with a little CX and let sit several days to ease removal.
If they still don't come out you may want to seriously question the integrity of the rest of the fuel delivery system as well, but I'll bet they will come out fine.
Look for two things
1) signs of degredation of the resin due to ethanol...i.e. softening of the tank or tell-tale goo in the motors
and
2) signs of blistering or delamination that might have been caused by ethanol, or might not. It doesn't really matter what started the blistering or delamination, ethanol will exploit the weakness it and make worse.
Look for two things
and
Users browsing this forum: No registered users and 17 guests
