What does a Glass tech deck cost these days?
Does anyone have an idea of what a Glass tech deck with the passageway between the engines sells for these days? I might have a line on an unused one.
I bought one 2 years ago deck, engine boxes and wings. I picked it up 7K.
It was supposed to be all composite no plywood.
Well when I trimmed the wings I hit plywood. When I predrilled the deck flanges from underneath so there would be no deck hold down screws showing from the top, I got ply shavings on the drill bit.
Lying sacks of crap.
if you are buying just the deck and the passageway and you plan on using your existing engine boxes you will require EXTENSIVE fiberglass work to that passage way to work.
I also feel it was designed around diesel motors because it does not fit in any dimension whatsoever on a gas powered 31.
we cut one in 8 pieces and chopped and diced it in everyway to fit into a gas 31.
im about to sit down and watch some tv when I remember the other issue with the passage way insert- it did not fit in the boat we were trying for and aft either, almost like the bulkhead was in the wrong spot for the passage way insert, Bertram must have varied the engine compartment bulkhead or the cabin bulkhead placement ever so slightly
That boat looks good though.Raybo Marine NY wrote:if you are buying just the deck and the passageway and you plan on using your existing engine boxes you will require EXTENSIVE fiberglass work to that passage way to work.
Users browsing this forum: Bing [Bot] and 70 guests
