Bottom Paint and Shaft Logs
Hi there. Two different issus.
1- Shaft Logs
Turns out I got a call from our captain saying that the bolts from the shaft logs are squirting water out while the boat is running. He says they wont leak once the boat is sitting. I am worried about it. Is this common?? What is the fix??
2- Bottom Paint
How much paint does it take to do a bottom job on a B31??
Thanks for your time.
JC
1- Shaft Logs
2- Bottom Paint
JC
JC,
The old bronze shaft logs are a source of evils which can even include damage to the hull fiberglass through electrolisis.
As a standard rule I remove the bronze alleys and replace with fiberglass tubes as Russ mentioned. See the Tips Section on Fiberglass Shaft Log Replacement...
Unless you know exactly where its leaking, removal of box clean off all that crap and rebed.
That bedding job shows its leaked before and was Ru Goldberg'd.
Trouble is some of that caulking could be hiding a deteriation of metal.
Ain't nothin like seein your boat sitting on the bottom and sayin, I should a taken care of that leak.
OK. Sounds like I need to get the boat out of the water and do the job ASAP. I dont know of any professional here that can do it. I could probably do it. Is it an easy job?? Is there a forum discussion were it explains the steps to do this?? If I take out shaft log I need to take the entire shaft out?? Right?? Help please... some pointers would be most welcome....
JC
JC
JC,
On the underside of the boat is two metal strips on each side under the stuffing box.
This supports the heads of the screws, ie acts as a strip washer.
The screws go up into the stuffing box on each side as you can see in your picture.
Remove all screws. Will take two people. One underneath, one above.
Once all screws are removed, gently pry the strip washers off. Metal is soft so be carefull.
Then loosen packing nut. Insert stiff blade scraper in between stuffing box and hull to break bedding. Once loose slip stuffing box up shaft and out of way. Clean off bedding on hull then spin stuffing box around and do the same.
Lay bead of 4200 around hull opening and slide box down in place.
Lay bead on washer strips and screws and insert and tighten.
Check all metal for deterioration.
If a problem don't reuse.
Clean off excess bedding compound.
Don't forget to tighten packing nuts.
- Trey Dibrell
HI There. I have been in touch with 3M in El Salvador and they say they dont bring the 4200 or the 5200 to the country. They do offer 3m 8664 marine silicone. That wouldnt cut it right??
What other brands or substitutes can be recomended. If someone can explain the properties of 4200 and 5200 I can probably search for a similar product. Sorry for so many questions but I am desperate to do this.... I dont want my baby in the bottom of the estuary!!
JC
JC
West Marine has a whole area of their website dedicated to International Customers, they certainly sell 4200/5200.
http://www.westmarine.com/webapp/wcs/st ... ction=care
jijiji LOL
Living in paradise can ba a pain in the a$$ sometimes. This is what they say..
Hazardous Items: Hazardous or toxic items such as paint, flares, fire extinguishers, batteries, epoxies, compressed gas and some cleaners cannot be shipped to International destinations. If you have any questions about this please feel free to call us on one of our toll free numbers.
JC
jijiji LOL
JC
Finally got the 5200
OK. After some searching I have been able to locate the 5200. How long do I have to wait before a relaunch??? Says on there 7 days full curing time but that seems way too long... can I relaunch before???
JC
JC
Atten: JC Shaft Tubes...
JC,Thanks for the answers. These are the shaft logs. I will try and do the fiberglass project at some time...
Here's what can be lurking under all that goop. If your hull fiberglass looks white and flakey under the bronze shaft tubes then you really need to address the problem by glassing in the tubes.
These images were taken today and there is no other sign of electrolysis anywhere else on the boat. If your running gear is in the bad shape you describe in an earlier post, you can just about bet that you've glass problems also...
Click on the image for a larger view
- John Jackson
I just watched Carvers install ones in my boat that look just like Capt. Patrick's. I do a lot of work on my boat but I think you would be out of your mind or way above average if you tried this job on your own. This is a major job. I think screwing it up could lead to disaster. With all due respect, it might be the type of thing that if you have to ask how to do it, you should let a professional handle it.
- John Jackson
Brass shaft logs
JC- I took a look at the shaft logs that just came off of my boat. They look like they are in very good condition. My shafts were 1-1/4, but I don't know if it makes a difference, or what size shafts you have. I also don't know if the original brass shaft logs are something you could buy anywhere or if they are Bertram parts. You are welcome to have mine if they will help you. Just pay for the shipping and make a donation to the site.
Users browsing this forum: No registered users and 356 guests
