I know they are sold at every marine supply, but I have heard they are an EPA no-no. What is the law on Y valves, does it vary from state to state?
Besides the fact that it's not cool to introduce the other boaters in the marina to your floaties.
What's the legalities of "Y" valves?
I was told that the diverter valve handle has to be secured in the position that sends waste to the holding tank while in waters where discharging the waste overboard is illegal, and using a simple electrician's plastic tie wrap is sufficient. I keep several of these near my valve so I don't have to worry about being able to locate one. All the diverter valves I have seen lately have the ability to be "locked", but the nice thing about tie wraps is you can usually find a way to lock almost any size or type of valve. I am always misplacing keys, and I wonder about some cheap locks in the damp marine environment maybe corroding and freezing in the locked position.
i missed all these posts until IR GUY mention it. i assumed you guys knew the Y valve goes AFTER the holding tank.all waste flows into holding tank and if you offshore you can dump it at your leasure. please don`t come to new york or mass. with a holding tank with Y valve before tank. thats could my grandchildren in the water . not a good way to make friends, what if you forgot? the other way you could be in harbor and the poop boat could do waste removal .just leave valve in off position ALL the time and when your offshore empty and shut valve and put tie on.
Users browsing this forum: Google [Bot] and 453 guests
