Washdown raw water pump - where do you have yours mounted?
I picked up a transom baitwell for my new to me B-28. I plan on feeding it water with a raw water washdown pump - I have mounted the "out" behind the port cubby - But before mounting the pump I wanted to ask some opinions - I plan to put a Y fitting off the head water intake - Where to mount the pump?
- Skipper Dick
Thanks Dick
Mine picks up from a thru hull at the transom with a ball valve and the pump is mounted vertically (motor up) under a deck hatch with the output plumbed to a faucet on the panel between the stb. motor box and side panel......B31. Mounting the pump with the motor up goes a long way in keeping a leaky seal from getting water in the motor. All the washdown pumps are pretty much garbage anyway tho....
UV,
Thanks UV, makes perfect sense and I will mount mine that way in the boat, when I get to that point.Mounting the pump with the motor up goes a long way in keeping a leaky seal from getting water in the motor.
Mine is on the port bottom aft of bilge pump, just off the keel, 1-1/4" valve with screen pick-up. 3000 GPH Rule feeds 3/4" washdown and T to 2- 40 gallon oval livewells with stainless spigots to control each livewell flow, located behind each engine box. Livewells are fitted with cushions for extra seating, same height as engine box cushions. Also can be used as a 4th bilge pump if need.
Thanks for the replies - very informative
Users browsing this forum: Google [Bot] and 198 guests
