Can you glue Amtico to Azac?
I am planning/hoping to replace my cabin flooring with Azac and want to cover the Azac surface with Amtico strips. Amtico recommends using their acrylic glue. I wouldn't want to go through all the trouble and expense and find the surface doesn't accept/hold the glue. Anyone have any experience with the surface? Walter
hold on brother lets talk! azak is not a floor material to be covered, you would want something a little more rigid you are spanning 2'.best remove old covering from floor hatches and put amtico over if your looking to reduce weight in cabin (i tend to think this is not your concern) build hatches out of 3/4" coosa board then cover with amtico.
Users browsing this forum: Bing [Bot], Google [Bot], Sweetnut and 91 guests
