Fuel filter
Fuel filter
Hopefully this is an easy answer. I have a B28 with a single fiberglass tank. At the fuel pick up point in the tank, is there any tipe of debris filter? I am troubleshooting a fuel problem and don't want to pull it if it is an unfiltered hose in order to check it. Thanks.
- Skipper Dick
Hookshurt,
Around the bronze pipe pickup, there is a fine screen brazed on. You can pull the pickup out of the tank and clean it. I did mine, but you should pull it out gently so stuff doesn't fall off of it, it was pretty clogged with varnish and stuff. I used a brush and a cleaning solution, but you could probably use soap and water if you make sure it is good and dry when you put it back.
Dick
Dick
- Skipper Dick
