battery & wiring questions
Hi guys,
I want to build battery boxes and install new cables. What should I use?
I have always used the 24 group battery.
1 battery for the port and 2 for the sb on a [1-2 or both battery switch]. one of the 2 would also handle the electronics.
Is #1 cable ok?
Should the VHF, Radar, AM/FM, GPS, etc come off of the battery directly
or a fuse strip in the bilge [forward bulkhead] electric box fed from a #2 cable from the battery switch? or the battery directly?
or a fuse strip in the bridge.
Thanks in advance Gary
Is #1 cable ok?
Gary,
What I have set up are 2 batteries (8D's) one for each engine. I added a heavy duty battery with an on off switch on the bridge cabled back to my starb engine Alt. I added a fuse bolck and run all my electronics of it. What I need to add is an inline sensor (forget what its called) to control what battery needs charging. Has worked for me for several years.
Capn' Tony
Capn' Tony
Gary,
I'd keep the cranking batteries separate from the house/electronics battery. Wire your cranking batteries on the main battery switch, (on/off. 1, 2 , both), and just an on/ff battery switch for the house. If you wire electronics to a cranking battery you could damage something electronic, you'll lose powere to the electronics if they are on and you crank the engine, and you can get noise from the engines that will give you interference problems.
On the cranking batteries, wire in a parallel circuit using a starter solenoid or relay. If one of the cranking batteries is too low to crank the engine, just push a momentary spst switch on the bridge to instantly parallel both.
Cable size is dependant on amp load & wire length, A standard chart can be seen here: http://www.alternatorparts.com/wire_size_chart.htm
The only things connected directly to the batteries should be the main cables, isolator, and charger leads. Every thing else should come from a DC electrical panel or at least a terminal strip or fuse block, supplied after the battery switches. Bilge pumps should be connected before the battery switch(s) so that there is no way that they be accidentally shut off. Unnecessary wires going directly to the battery should be avoided.
Spread the bilge pump hook ups between the batteries, only one pump per battery...
I have two group 24 batteries for cranking and an 8d on a shelf in the bilge between the engines for the house bank. I run a combiner for the two starting batteries off one alternator and the house bank off the other. I went way oversize on the wiring for the house bank as it is in an engine space.
Daydreams...
Send me an email so I can have your address and I will send you a writeup I just finished on what I just installed in my boat. New batteries, made new boxes, new panel, and a complete rewire of everything in the engine room. I have not yet installed a splitter but everything else is documented.
"IRGuy@aol.com"
"IRGuy@aol.com"
At all costs try and prevent the use of isolators and use battery switches to combine charging requirements.
The voltage drop across the isolators can be up to 1 volt on cheaper models and will prevent your battery from getting fully charged.
While this may never lead to cranking problems, in the majority of the time it will lead to shorter battery life and its just another device that is really not needed.
The redundancy of cross wiring the charging systems to charge everything off one systme is just silly given the reliability of altenators today and battery chargers.
By using battery switches you get the full charging voltage and the ability to manualy control your charging.
The house battery is normaly hooked up to the shore charger. So when leaving the dock, it has a full charge and a fully charged properly sized battery for your load will provide power all day without the need for additional charging.
By putting in a 1/2/both switch to one engine or another it gives you the ability to charge the house from an engine if you decide to do an over nighter without the voltage drop of an isolator.
Remember the kiss principle, it will serve you well.
Bruce...
Thanks for the advice. Actually at the present time my house battery is wired as you suggest, being recharged only by shore power. I have considered installing an isolator so one engine can recharge it after it has recharged it's starting battery, so I can always be sure of having everything recharged, but a manual switching system makes a lot of sense (as long as you don't forget to make the switch changes!).
<a href="http://s187.photobucket.com/albums/x54/ ... 010003.jpg" target="_blank"><img></a>
Installed these much lighter batteries in the cabin bilge to power electronics and start two Cummins. Does the job admirably while being lighter and at a low center of gravity. Usually this space isn't used anyway so good solution.
Not sure why the image has decided not to post, click on it.
WOW, its amazing all the really good options. I'm going to ask a few questions and then read this post 3 - 400 times before I will be able to decide which way to go.
Should all 3 neutrals be joined no matter which set up?
Should the neutrals at the block go to bonding?
If one engine starts from a pair of batterys [1-2 or both batt switch] but charges the house battery only does that batterys neutral go the that engine block?
I believe that usually the alternator charge wire goes to the batt on the equipment side.
But in this situation the alternator should go between the battery and the switch to prevent forgetting to turn the switch on and causing alternator damage?
If 1 batt did port engine and bank -#1 batt did SB engine and #2 batt did the house would the neutrals be connected parallel?
I like the solenoid jumper idea. I expect to work that into my system
Mikey nice batterys. I have water tanks in that area. those must be the gel batts no fumes. nice job.
Ed what is a combiner?
Thanks everyone your time and info is very much appreciated.
opps, I was laying in bed at 4:00 AM thinking its to early to get up and I realized that I called the battery negitive / neutral. I figure it's due to stress, a senior moment or just thinking too far ahead. I'm going with the latter.
If you are not using your boat for overnights on a regular basis why do you need fresh water tanks? I carry jugs and find this more than sufficient. That's why I eliminated one water tank. The other I am contemplating using for waste from the head.
Bruce...
Re: Your post above...
When underway and you want to manually change the alternator's output to charge another battery do you have to shut down that engine so the alternator won't suffer any damage?
Maybe a dumb question but better to expose my ignorance here than later at sea.
Randall,
I used some lead (tire weights) to balance the boat. They all seem to list to starboard. Think they must have anticipated gensets.
Rawleigh,
Fresh water washdown at the dock. Don't need the extra weight. It may not be much but . . .
This is what's interesting about this group, variety of thought. Through the years that I spent renovating Dreamsicle I asked many questions and got as many answers. I think the results to date are pretty impressive and all due to the many different thoughts on any subject.
Keep'em coming!
Rawleigh,
Keep'em coming!
Users browsing this forum: Bing [Bot], Google [Bot], Sweetnut, Tommy and 403 guests
