Gear ratio
Gear ratio
As some might know I am getting new (to me) gas engine, Question is I think the original gears are 1.5:1 is that right for 454's with BW gears? I tried to look at the gears, but no markings or plates. Too Much paint and years on them
Scott Traenkle
Thanks guys, I was pretty sure it was 1.5:1, however I just talked to Eddie Johnson and he wants to put 2:1 ZF gears and run a 22x20 prop on the 1 3/8 shafts. Bruce or anybody else have feelings about this set up?
I thought I would be running a 1.5:1 and keep the same 19x19 props I have, but he does not have 1.5 gears only the 2:1. I am sure he knows these set ups better than I, but if anyone has issues as to which might be better, or is it half dozen one way and 6 the other I would like to hear.
Scott Traenkle
Scott-
My friend's '04 31 Tiara had 496s with 2/1 gears and turned pretty big wheels--but on 1 1/2" shafts. That boat also had the 385 hp 496s, was a little bigger and heavier than our 31s (although with slightly less v), and turned up to about 38 knots. You'll have a 40 knot plus B31 easy--careful.
- Capt Dick Dean
Coming clean.
This is just about good as any time to unload the truth about the Irish Wake. You remember her, she went aground last yr in Shinnecock and has been on a lot of sand bars prior to that one. Dam near a sand bar a yr. I also have to own up to the speed of the boat that was always thought to be fast. That was what I led people to believe. WOT gives 28.5 kn. Even with the hi-tech air filters and profomance plugs, a clean and smooth bottom.
The reason for the download now is likened to the criminal that just has to tell some body. Like the cops. That he commited the crime 20 yrs ago. I can't go on any longer.
Let me say that when I was buying the boat in 1998, I asked the salesman how he knew that the boat had big blocks. ( Big blocks to me are 454's). He said he just knew. He could tell. It troubled me that a 325hp sticker was on both engines. Well, having a sail boat for 20 yrs, what do I know.
The truth came to me a couple of yrs ago and really hit hard. I am still suffering. It started with an oil leak in the bilge. I found the source at the oil filter on the engine. Yeah, it was the seal from the oil filter housing connecting to the block. At the Mercriuser store, the parts guy show me pictures of the 454's. But my set up didn't look like that. So it was recomened that I go and get the serial #'s off the block which I did. As I was reading the #'s over the phone, the parts guy stopped me cold. My # started with a 3. 454's start with a 4. I gasped for breath.
"What yr is the boat?", he asked.
"1972", I replied
"You got a 427. 454's started in 1973"
I got screwed. I had to tell somebody a month or so later. So I told Capt Harv. You know him from fishing in Jersey. I made him promise not to tell anyone especially the 31 group. He promised. The last summer he tells me that Capt Patrick knows. And for some time.
"How the hell does he know?"
"Wasn't he on your boat in Montauk helping with a starting problem four yrs ago."
"Yeah, he was."
"Well,do you thing he didn't notice with the 325 sictker on each engine? He never said a word, did he? And he never said a word when you were shootin' your mouth off all this time. Geez, you went on and on for yrs, So I didn't tell him!"
"Boy, do I have egg on the face."
"You got egg all over you!"
Boy, I feel better. A load is off my weakened old frame. I feel can live again ....
See ya at Montauk.
"1972", I replied
"Yeah, he was."
See ya at Montauk.
A/K/A El Gaupo
Depends if you want to spend more money. The 1:5's will work fine.
The 2:1's will swing larger dia props = more efficient. A bit slower, but the boat will have less % of slippage with the larger wheels. The boat will also be less effected by sea state with the 2:1....meaning the varing loads on the engine will not be as dramatic.
Now go do the right thing???
- Capt Dick Dean
Scott,
I didn't mean to hi-jack your thread. Just had to get it out. And I thank everyone for the kind words. You really think 427 have better or just as good value. I thought I just lost 10 grand.
But to answer the question, I have Velvet drive series 72c w/ 1:1.5. Had 18x18 Michigan quads and just last yr took an inch of pitch out. Was turning 3500 rpm and now with the 18x17 wheels get 3950 rpm's. Boat feels like it's not lugging. Engines sound better @ 3000rpm. I may still be over proped.
A/K/A El Gaupo
Plenty of Corvette guys would be willing to buy them if you wanted them out.Capt Dick Dean wrote:Scott,
454's are basically a 427 with a little more stroke. the 427 is internally balanced vs extrenally balanced for the 454.
pro and con for both...
biggest difference is displacment... like 327 vs 350 in small blocks...
both can make good power and a few cid has little effect.
IIRC, the engine blocks are same with the crank, flywheel and harmanic balancer individual to the 454. 468, 496 and 502 are all larger versions (bore and stroke) from the 454 layout.
ok dick because you are my friend i will clear this up:forget serial numbers i can punch in anything you want.the real deal is the engine casting numbers looking from the rear of the engine looking foward the casting numbers are on the left top of engine.here goes 3869942 you get free mercruser 454. 3904351 is winning the lottery you get yanmar.if the front right cylinder block is marked je follow by 7 numbers you get the yanmars and bruce to install them!any other numbers are no big deal how ever 427 has forged steel the 454 in the hp range that you find in a bertram is cast iron junk and so are the cylinder heads.
Users browsing this forum: Bing [Bot], Google [Bot] and 218 guests
