Smart Rails...
Smart Rails...
Anyone here ever installed them on a B25 or a B31? Curious about their performance, ease of install, positives/negatives...
CMP
CMP
Mark,
They do a pretty good job of reducing spray on the B31, and I'd guess that they work as good on a B25. Installation is pretty simple and if installed correctly are close to permanent and indestructible. You do need to carry them back past amidships, but not necessarily full length of the chine. About 2/3 back from the bow would probably be fine.
Of the two extrusion designs, the only one that comes close to fitting the Hunt chine still needs a bit of modification in my opinion.
I experimented with the installation on the B31 chine and found that by cutting a notch in the rails it allowed the rail to more easily conform to the chine.
Cosmetically, they're butt ugly...
Actually, because the Smart Rails are made from a plyable PVC compound, they're not as suseptable to lift damage as hard spray rails. They still do need chine blocks on the slings, but any competent boat yard is already familiar with the proceedure.walterk wrote:The only complaint I've heard is that they must be protected from being crushed by the lift straps when the boat's being hauled. Walter
- thuddddddd
Taco Spray Rails
You may want to look at these, scroll to bottom.
http://www.tacomarine.com/cat--Rigid-Ru ... solid.html
Steve
Steve
CMP,
Had them for several years and no issues except the one side cracked-out near the end of the run after being on since 2003. I have full set plus another half set which comes back about 15 ft. total per side. If I were buying a 31 again it is one of the first things I would add after Capt. Pats rudders. One thing I don't like, other than the looks, is in real heavy seas they don't do much since the waves are hitting the sides above the rails. I might add a second set this spring just below the rub rail and see if these cut even more spray.
Dan
Dan
CMP,
Sorry, but no pics on the boat. The set that have been on for years are down along the chine and not super noticeable. However, the second set I am considering adding would be the series that attaches to the flat hull side and would be much more visible. A good friend of mine in OC has been installing these for several years and has actually painted many sets with Awlgrip and had good results just as long as your not banging them into docks which should only be an issue for me at our fuel docks and if I only extend them 10' back on each side, they sould be far enough forward not to be hitting anything. Jimmy gave ma a small section which I will tape in place just to see how ugly it really looks.
Dan
www.finchasersportfishing.com
Dan
