![Image](http://bertram31.com/hancock/img/cockpit/eng_cmpt/engines/exhaust/leadin.jpg)
Exhaust System
Exhaust System
Persuant to Ian's request for more images of the B31 I'm working on for Patrick Hancock, here's a non-verbal image rundown on his exhaust system...
You know how it goes. When you work alone, you figure out solutions to just about everything that will keep you from tracking down a neighbor. Mechanical Advantage is tool box necessity. Just as you did with the hydraulic jack on the windshield corner. Sure could've used one of those puppies on several occassions...
Now if I can figure a way to put these levers to useful advantage:
![Image](http://bertram31.com/llano/bevo_sm.jpg)
Naw, Hook'em Horns!
This was at my niece's rehearsal dinner in Austin year before last. My sister's husband pulled some strings and got the handlers to bring Bevo, (#7), to the shindig. Been thinkin' ever since that I might just have to fence in the rest of the property and cut a longhorn loose on it. Cool animals...
JP,
Yup... The side panels have a toe kick and the outboard deck joists are glassed, filled and faired to the inside of the hull. The 1 1/2" PVC pipe extends back through and dumps on what in essence is a water race. the water is kept below the top of the deck, but, for the most part, won't run into the bilge. Straight back to the scuppers...
![Image](http://bertram31.com/hancock/img/cockpit/panels/pt_panel4.jpg)
![Image](http://bertram31.com/hancock/img/cockpit/panels/pt_panel2.jpg)
![Image](http://bertram31.com/hancock/img/cockpit/panels/pt_panel.jpg)
![Image](http://bertram31.com/hancock/img/cockpit/panels/pt_panel3.jpg)
- AndreF
Them's long-horns are gittn pretty scarce these days. You're lucky to have touched one.
Thanks for the photo, Captn
1981 FBC BERG1883M81E
Users browsing this forum: Bing [Bot], Google [Bot] and 84 guests
