fuel tank sending unit
- Terry Frank
Sorry to ask the question that's been asked too many times already. What's the manufacturers name of the recommended fuel tank sending unit. Thanks.
Terry
Terry
Terry
Terry
Terry-If you have a sending unit in your tank that is presently non-functional, before you buy a new one check the grounding on the one that you have. If you DO have to get a new unit, if I am not mistaken the bases and screw configurations are standard. I found on my 20, just the removal and re install of it made it functional again. I'm sure Patrick or someone will come back with the exact specs. All the best for the New Year! Walter
- Terry Frank
I got hooked up with Isspro looking for a good quality guage maker and have not been disapointed.
I turned Pat onto them and he liked them also.
I was tired of the cheap Teleflex, Faria and other crap on the market.
I always believed if your gonna put guages in, might as well use ones that read accuratly otherwise use idiot lights.
All my surveys over the years have showed just how far off the cheap crap guages are.
Sending unit for fuel tank.
Bruce,
do you have the model # from isspro for the stock tank sending unit. I'm not sure on the length of the sending unit. Thanks and Happy New Years to all. Aloha
1977 Bertram FBC 1688 M77L
Giff,
Pull your old sending unit out and measure the inside depth of your tank and the Isspro length should be 1/2" to 1" shorter than the depth of your tank.
DQ
DQ
"IN GOD WE TRUST"
"IN GOD WE TRUST"
To all, thanks for your replys. I am on this. I orginally use the Faria unit that was supposed to be for the guages I bought *Had I known about ISS then, I propbabaly woul not have put in Faria guages*. I cut the lever arm so it would clear the baffles. Worked for about 1 day underway. This is the only thing that did not work right after my rewire job.
Bob sounds like your boat and mine were manufactured at close to the same time. Mine is a 1973, though I don't know the month. 231 gallon tank for a Cummmins 504 right out of the factory. Hull is 315-1297, could be that our boats are crib mates.
Giff
Users browsing this forum: Bing [Bot], John Nardi and 477 guests
