What's the best way to lift a 31 ?
- JohnCranston
Greetings,
We need to lift Reel Cowboy up about 5" off of the trailer, so that the bunks can be adjusted. We don't have a travel lift available and she's not ready to be launched off of the trailer quite yet.
Thanks for the help.
- Terry Frank
- JohnCranston
I had to do something simular a few years ago for my 31.
I used 2 floor jacks (fore and aft) to lift 1 side off the bunk a couple inches so I could adjust it.
I used small jacks-- 2T I think- 1 side against the trailer, other side against the hull... used a 2x4 to distribute the weight against the hull.
Quick and dirty solution to adjust 1 bunk at a time or to paint area.
Ray
Ray
On a smaller boat, I used Archimedes principle... "Give me a lever long
enough and a fulcrum on which to place it, and I shall move the world." With boat on the trailer, I used 2'x6'x12' with trailer as a fulcrum. Lifted by sections and placed jack stands with boards to lift boat off trailer by 3".
Needed to replace leaf springs. Just a thought.
you can try to lower the toungue right to the floor, best to do this with a floor jack so that you can get it as low as possible.
This will allow you to block the stern up, at that point lift the toungue back up, when you do this it will take most of the weight off the bunks.
Place blocks under the keel, lower the boat onto the keel.
Now the boat will be off the trailer. At this point you can jack the boat up a little at a time if need be with jacks.
- JohnCranston
Users browsing this forum: Google [Bot] and 130 guests
