cockpit panels
cockpit panels
Hi guys, I need to replace the rear cockpit panel (sides are O.K.) and was wondering what material that is and were I get it? This is the rear inside section of cockpit that looks/feels cosmetic , no structural. Any thoughts?
Rocky.
Rocky.
Rocky,
The transom panel is longer than the side panels, around 106''. When I had my boat building company, my glass guys layed up gel coated 3/8'' core matt panels, you have to have at least a 10' flat layup table. I attached fiberglass U channels to the back side for spacers to get rid of bowing in when you lean against them with your knees. I've also seen the panels made of PVC foam core board, Starboard(it's heavyand yellows over time) and Formica faced plywood like the originals.
Pete
Pete
I think AZAK may be really similar to Kallite, made by Kal Wall corporation in NH. It is the dimpled fiberglass panelling you see at HD etc. It comes in various sizes and thicknesses, and is very workable, paintable, sandable, etc.
That is what I used and my only regret is that I didn't go thicker. However it is very durable.
I'm happy with it.
I'm happy with it.
Does anyone have a link to a source of Azek or similar (PVC) panels? All I can find locally is trim moulding and boards up to about 7 1/2" width.
I read somewhere (Capt Pat's Building Tips comment?), the dimpled thin sheet stuff available in the Lowes and HDs of the world is fiberglass. I am wondering if it makes sense to try to laminate two of these together? I would like to have a smooth side show, so it would mean having at least one dimpled side as one of the inner faces.
Bill G... I can get Azek or a substitute in trim and board form at my local Home Depot or Lowes building supply houses. It is known by several names.. I suggest you ask for the "PVC imitation wood" or something similar. Most of the guys in the lumber section of these stores down here look like a deer in the headlights if you ask for "PVC lumber".
here ya go Bill:Hey guys where could I buy AZAK I'm in N.J.?
http://www.azek.com/whereToBuy.php
Rocky,
I'd go with 1/4" divinycel, laminated with glass on the rear & formica on the facing side...you can join(glass) shorter pieces together.
But I've never worked with Azek either... I'm just not crazy about any of those "composite lumber" products.
Sounds interesting and like its a great choice, but what exactly do you mean by acrylic?this is why acrylic is a great choice, it comes longer then 8', and there is no need for a heavier thicker panel.
Acrylic is a really broad term just refering to acrylonitriles, or various acryl compounds, acrylic resins, etc...
Do you have a product name, or a source, or any more info?
the beauty of azak is you dont have to do anything.....cut and fit...or you could laminate formica for a hard finish....but i didnt on my little side covers.....no real use yet but it is so easy to work with .....and totally impervious. i think it comes in 10 foot lengths, 4 foot wide.
![Image](http://i112.photobucket.com/albums/n186/randallro/IMG_0018.jpg)
its that little vertical cover by the gas fill
azek comes up to 4'x12' ----1/2,3/4,11/4, used by professionals only a bayliner owner would even think of going to hd for anything that he intents to keep.
put old piece over scribe cut but make one change ;at box built around scubber exit frame around entire box then apply 3m 4200.use as a toe kick an also increase (funnel effect) flow to scubber.should take 20minutes with piece left over to cut in half for bottom pieces in companion way under hatch covers 54" each.
ok i will try this one more time.first of all we puchase a 4'x10' piece of 3/8" or 1/2" azak because the transon cockpit panel is 9'5" so you want to make it in one piece.now look at the scuppers .they have a small opening leading to the actual scupper on the outside of the stern.what you what to do is cut out the transum cockpit panel to match the size of the actual box bertram made of marine plywood.now traced this "box" on the old panel cut out and lay this panel on the new azak. we attach the new azak to the wood rail inside the gunnel with ss parker screws but the bottom we lay a bead of 3m 4200 on the face of the box and make a waterproof seal along the cockpit floor this will eliminate the teak strip along the cockpit floor as randall point out in his photograph.i hope i have not lost anybody! ok so now you have tnis left over 2' x 10 piece.you can use this to replace the rotten wood panel that is directly under the engine hatch facing the companion way if you install from bulkhead to bulkhead it will be 54" long so you can get both sides out of the 2'x10' leftover.make sure to put a 45degee cut at the top of these pieces to match the closing part of the engine hatch and a vertical piece in front screwd to bulkhead so this panel cannot fall in toward engine. rear part of panel also has a 1"x 11/2" vertical piece to prevent panel from moving in the outside of panel is hel by the step now when you work on engine lift hatch and put straight up to remove panel NO SCREWS!!!
tony brain farts are common at 62years old and i make the mistake of thinking everybody does this every day i am wrong and wil be more patient in the future.i also should have told every before hand that my intention were to eliminate that troublesome teak strip that borders the cockpit floor and make a clean joint at the floor with no maint. 3m-4200 is totally uv resistance and a perfect match to azak brand pvc board no screws needed.
Bob- just to clarify, 4200 is NOT UV resistant, neiter is 5200.
The off-white color of a bertram will hide this at first but as the sealant gets older it will yellow further. If someone was also to use teak and get teak cleaner on the 4200 it will turn even more as it is not resistant to teak cleaners.
We never use 4200 or 5200 as a finish bead, its always best to use a different sealant, sikaflex makes great UV resistant sealants that have the same strength as 4200 and 5200.
robbie that should have been 3m 4000 uv.uv resistance and will not yellow i do not use 3m 4200 for anything!
not on the subject but related.the toe holes in the cockpit panel i mention above are essential for big game fishing.shark,big eye,and bluefin tuna the wireman put both feet into scupper cut in panel and this adds tremendous leverage,the gaff man is on his right and will use the toe holes when sinking the flying gaff.a 200 pound plus mako gets crazy after a gaff shot and falling in the water with a mako can ruin your weekend.i will photo today
- Capt.Frank
- Capt.Frank
incidently capt.frank azak loves the router.you can run the roundover bit over any edge and make a nice clean cut however you must use carbine bits and get the feel of the router feed which is quite fast.there are at least 8 differant glues but azak brand pvc glue works real well especially if you break the glaze with sandpaper,and drys white.if you must use scews in a hidden area use 316ss deck screws very fast worm, with recessed square head drive then fill in with filler.building a bulkhead takes a couple of tricks and the use of plexus glue any other structual use of azak like a battery box will also require the same glue,and rabbited joints. according to costal contruction (professional building publication) azak held up better than any other product in hurricane construction and the effects of salt water on waterfront holmes.
Users browsing this forum: Bing [Bot], Google [Bot] and 197 guests
