pulling engines
yes there is john.as a brother and the amount of time we spent on the comp. i have to tell you this if you don`t address the engine oil removal tube now it will be a bitch later.remove oil,remove rear oil pan bolt and install one piece 2 foot hose with molded threaded end into oil pan and garden hose male at top end.wire tie to starboard of port engine and port of starboard engine.5/8" id is perfect size to remove oil.also i would do gears at this time.same hose wire tie to stringer.optional if you are anal a oil relocation kit for starboard engine places both oil filters inboard change oil and filters with a suit on!
Users browsing this forum: No registered users and 168 guests
