In the Market for a 31!
Just sold my 25' bertram out in Hawaii and will be getting stationed back in the states! I am going to start looking around for a 31'! My question is what are the differences in year boats? Any other suggestions? What are the major upgrades to be looking for? Unfortunately cant afford a SeaNile, Buddy Boy, etc.. but would love to get one and spend a few years getting it up to that caliber boat!
THANKS,
ANDY
THANKS,
ANDY
Any of the years have plenty of glass. The later the boat generally the lighter the hull and the more fuel in the tank.
By the mid 70's Bertram had made the final design changes to the lifting strakes, these are considered by most to be the driest and best performing hulls. All of the B31 hulls are designed ahead of their time. I don't know if most of us could tell the difference.
Look for a later hull because of the gelcoat crazing issues associated with the earlier hulls. If you can find a late model hull with diesel power over 250 hp per side you'll be a happy camper.
Depending on where state side you'll end up the East Coast is chock full of B31's for sale in varying condition. Have fun and good luck.
I am from Alabama (GulfCoast) and will be stationed near that area. When did they stop putting helm stations in the cabin (only want 1 set of controls)! Are there any differences with engine compartment dimensions on the later vs earlier years? When you say late 70s are we talking about after 75? What was the last years the 31s were built? Thanks for the info
-ANDY
-ANDY
There are essentially 4 models. Bahia Mar, Flybridge Cruiser, Sportsfisherman and Express Cruiser. Based on how you like to fish and live (on board), here is how I've looked at them. All are great boats. The Bahia Mar and Express Cruiser (no flybridges) are the easiest boats to run alone as you run them basically from the cockpit. Both have standup heads which women usually prefer. Visibility ie: lobster pots, logs, etc., less than on a flybridge model. Express Cruiser has you standing a bit higher as you are on the engine box. The classic is the Flybridge cruiser which has the enclosed back. Standup head, lockable, air conditionable. If you are in the least claustrophobic, the Sportsfisherman might be considered as it has an open back with rolldown canvas for sealing up when you go home or live on board. The tradeoff is the head in the sportsfisherman is between the V-berths, under the V-berth filler.
All models come with gas or diesel engines. In the USA the introduction of Ethanol has created major engine problems due to the fact that Ethanol has been found to dissolve and delaminate our fiberglass tanks. At least in pre 1980 models. If you're looking at gas engined boats, make sure you have aluminum tanks in the boat. As far as diesels go, Cummins B series and Yanmars seem to be the most popular. If you're choosing one or the other, look into the availability of service capabilities nearby.
When it comes to age, you will find the older models (the 60's) seem to be much heavier hulls as at that time they didn't know how much fiberglass was enough so they opted for more rather than less. Based on the roughness of the waters you may ply, you might opt for heavier over lighter, but that's a subject that can be argued for hours, if not longer. Hope this was of some help. I'm sure our other Bertram 31 bretheren can (and will) chime in on the plusses and minuses of each. Most everyone swears by what he owns. Welcome back! Walter
Are you sure you want to leave Hawaii?
Not all 31's came through with the lower station. That was an option. On a Fly Bridge Cruiser or Sprotfisherman model, its tough to see over the bow when running from down there, but depending on how you plan to use and type of weather you may want to look for one with it. I think you will find more without it.
Like JP said, look for a diesel with at least 250 or more a side. Plenty around at good prices. Just be carefull of any coming out of the Gulf after the Hurricanes. Make sure they haven't been under water.
Thanks, I am leaning towards the Flybridge model (closed in bulkhead). In Hawaii I believe the open MODEL is better because the temp is always wonderful and a nice breeze. Back home (Alabama) on a humid 95 deg day on the Gulf I think It would be nice to suck up some a/c even if it is tight quarters! When does this whole extra glass theory start and stop (1960-1969) or what? Are we talking 1000lbs or a couple 100lbs?
ANDY
ANDY
Hell no! I would love to stay in Hawaii! But being back in the states will put me and my family closer to our families! I was stationed in Hawaii for 3 years and spent maybe 1 actual year in hawaii! But you better believe I made the best of it by getting a 25' shipped out and fishing it usually 2 times a week when I was here!
The thickness of the glass changed in 1973. Its a pretty good differance. My 1975 FBC carries 220 gallons of fuel and Bertram lists the boat at 10,000lbs. I have never weighed it so I can not attest to that, but a mid 60's FBC will weigh closer to 15,000 but only has 175 gallons unless the tank was changed. The size of the tank changed somewhere around 1972.
No matter which one you get, the hulls are pretty much bullet proof. They just ride a little different and the lighter models will cruise a little faster than the heavier ones with the same engines.
Andy,
I'm guessing that I picked the right face for your avatar. Just picked the one that looked most like a pilot...
I had 2 Cobras buzz my place a couple of days ago and take a closer look at the B31 I'm working on. Got waves from both crews. Last year it one lone Blackhawk. Did the same flyby & wave. Get pairs of Talons zipping over on a regular basis. Not sure which base they're flying out of, but I'm on their training flight path.
Good luck in your quest & welcome home.
Hello Andy,
I have a 1967/B31 FBC in Pensacola totally refurbished w/ 250hp turbo-charged Cummins 6bta's w 130hrs on totally reman engines, ZF220a gears, 300 gal fuel, AC 12,000 btu cruise-air unit w/ 5.5 Next-Gen, full Marlin Tower, Rupp-riggers, Murray Brothers fighting chair, loaded with electronics.
Or if you want another B25 w/ brand new Cummins 4bta w/ new Mer-IO install will need some fixin-up on the hull to creampuff it but has new engines w/IO's, O-HRS still has full factory warranty on engines if your interested, just let me know what your favor is and I can send some pictures to you with my cell # to call me if your wanting to see them when you get to the Gulf Coast.
Regards,
Doug
Regards,
Doug
"IN GOD WE TRUST"
"IN GOD WE TRUST"
Andy
They are pretty much the same hull wise. Some changes over the years in the lifting strakes and engine box size. Depends on what engines was put in at the factory. The interiors changed slightly over the years, but from the outside they look pretty much the same.
Good luck and safe trip home. I am sure you will find the one that is right for you.
Boy ! ! ! ! You Bay Minette people really get around. When my son Chris graduated from trade school he and I went on a diving trip that departed from Fort Meyers and went to the Dry Tortugas. It was a 3 day live aboard trip.
One day we docked and departed from the boat to visit Fort Jefferson. One of the park rangers met us and while leading the tour she asked where we were from. Chris told her that she probably never heard of our little town but that we are from Fairhope Alabama. The young lady burst into laughter and told us that she was from Bay Minette Alabama......its such a small world.
When you get back to Alabama and settled in give me a shout.
251-928-5291....or give me a shout here in our sand box.
Harry
Harry
:) Andy, I just happened to come across your interest in getting a 31. Mine is for sale ,buy not yet listed on this web site. I am a member of bertram31.com, so this is not a hoax.Please feel free to contact me thru fhermann@optonline.net if interested.
Harry-
I will definitely get in touch! The locals out here put there boat names across the front which is ugly as HELL! But I figured since I was here I would do the same thing in order to try to be a little more "accepted" by the locals! Anyhow, I had "ANNIE C., BAY MINETTE, AL" across the front! On 3 different occasions out here in Hawaii I had people from our local area in Alabama flag me down to tell me they were from somewhere in Baldwin County.
Small World
thanks
![Image](http://i306.photobucket.com/albums/nn274/amuh60/IMG_2602.jpg)
Small World
thanks
capt pat- ever have thier fuel fisheye the paint? Happened to me once!CaptPatrick wrote:Andy,
I dont think it has been mentioned here- but dont look for the heavier hull thinking its a better boat, the thickness of the hull is not a factor with these boats, a heavier hull will just mean more fuel consumption.
if you are going to restore the boat and the boat you find is original factors that would sway me would be the condition of the gelcoat, fuel tank, and engines.
71 brochure
Andy,
Congrats on the potential upgrade. Here is the link to an old brochure that gives origional specs if you want to see visuals of the different models.
http://bertram31.com/articles/b31_72broch.pdf
Joe
Joe
I was looking at the very last page where it has copy right 1/69. Sounds like everyone was saying that up until 72-73 the boats were weighing in close to 15000lbs but if the date and specs on your brochure are correct it sounds like around 1/69 they were 9600lbs. Anyhow, I appreciate the brochure it gives me a lot a details I was looking for. Now if I can figure out when these hulls actually got lighter!
THANKS,
ANDY
THANKS,
ANDY
Andy - My dad had two 31's while I was growing up, a F/B SF and a F/B cruiser, both with gas and both weighed about 10,000 lbs. The Bahia Mar with Yan Mar diesels being built now will come in just about the same. 15000 seems really heavy.amuh60 wrote:I was looking at the very last page where it has copy right 1/69. Sounds like everyone was saying that up until 72-73 the boats were weighing in close to 15000lbs but if the date and specs on your brochure are correct it sounds like around 1/69 they were 9600lbs. Anyhow, I appreciate the brochure it gives me a lot a details I was looking for. Now if I can figure out when these hulls actually got lighter!
THANKS,
ANDY
Andy,
Here's my cell # 850-525-6126 when you get settled in, early models 31's were about 2,000 lbs heavier thru 1970, then anything after 1970 were lighter because, they finally fiqured out how strong fiberglass was, the hulls are damn-near bulletproof.
But 15,000 lbs is a little extreme, mine weighs in with 300gals of deisel fuel and full marlin tower & fighting chair under 13,000. Most owners don't even know that there hulls are two pieces put together with a top plate put on last, but there has NEVER been one come apart.
R,
DQ
R,
DQ
"IN GOD WE TRUST"
"IN GOD WE TRUST"
Doug,Most owners don't even know that there hulls are two pieces
The B31 hull isn't a 2 piece construction... This myth pops up about every couple of years.
The hull mold is a two piece tool that was bolted together down the centerline from bow to stern. This was necessary because of the tumble home and chine design. There would be no way to pull the B31 design from the top of the mold. The mold, after laid up, stringers added, and cured, was un-bolted and removed from the hull laterally.
Because of the line left in the gelcoat from the joint of the mold halves, it looked somewhat like two half hulls were fiberglassed together. But that certainly wasn't the case.
The B31 hull, and for that matter, all fiberglass boat hulls, are laid up as a single part. The B31 hull mold was fixtured so that it could be rocked from one side to the other. The glass crew would rotate the mold so that one side was almost facing the shop floor. they would lay one course of fiberglass on the "down side", overlapping past the center line. Then they would rotate the mold in the opposite direction and do a course on the other side, again overlapping the center line.
Working back and forth in this manner, the entire hull was laid up as a single part. The overlapping center line fully ties & cross locks the two lay ups. This is the reason that the centerline can be as much as twice as thick than the rest of the hull. The overlapped centerline on an early 60s model could be as much as 1 1/2" thick...
Thanks Capt. Patrick,
I stand corrected, I probaly mis understood the person @ bertram years ago about that, when I was taking all the old bottom paint off in 1986 about that piece of fiberglass tape on the bottom of the centerline at that time. But I was correct about the hull weights, right ?
R,
DQ
R,
DQ
"IN GOD WE TRUST"
"IN GOD WE TRUST"
I pulled out the price list and specs from my boat. Believe it or not it was printed in Oct. of 74 and our boat is a 75 hull # BERG1467-315. The weight which they list as approximate was 10,600 lbs. For a comparison, the silver anniversary model which I also have the specs for came in at the same weight. Everything is identical except the price. The base price before add ons with the 350 Big Blocks in 75 came in at $33,600 and the 210 cummins was $48,400 and the 225 cats were $56,000.
The Silver Anniversary edition listed at $108,000 with 340 Mercs.
I still have the bill of sale from our boat. Purchsed August 1975. Basic boat with 350 Mercs was $32,600. When all was said and done the total was $38,910 and we paid $36,720 after an hour of back and forth.
Not cheap in 75, but work that out over how many years and its cheap compared to another boat that would be laying in the graveyard by now.
tony that seems to make some sense phoenix is berg 1301-315 built april 15 1973 and was oem with 210 cummins.i allways wanted to do a survey concerning the fuel tank.my tank is clearly marked 4/15/73 and 231 gallon.i wonder if the gas models were 220gal. and the diesel 231gal.we have a 1972 fbc in the yard with mercs. 170gal so the change in tanks was about november of 1972.they must have made two tanks at least in 1973 one for gas and one for diesel.my bert weights in at 9400 lbs empty.
- bobfioresi
Andy; I have 62 express cruiser that is in nice shape for sale. She has a marlin tower with controls in addition to controls in the lage cockpit. It is fighting lady yellow and has the same interior layout as a fly bridge' it has a new 233 gsl.SS gas tank and has a pair of 440 chryslers with 60 hrs on 1 and 0 on the other. It's in LI ny .39,000 iF INTERESTED CALL ME AT 631 668 4064. tHE DOCUMENT SHEET SAYS IT WEIGHS 9 TONS. pREVIOS OWNERS HAD 2 FLYBRIDGE 31'S AFTER MINE AND SAID NOTHING RODE LIKE MINE THE 31'S HE HAD WERE NEWER.pS I DOCK 3 SLIPS AWAY FROM WALTER IF YOU NEED AN OPINION BOB
Regarding gas tank capacity--As you know I replaced may tank and I don't remember what the tag read.
I checked my owners manual and the data sheet in the front where they type in the serial # also has 231 gallons typed in.
Going through the manual--in the fuel system section the printed pages show 220 gallons and the diagram has the tank labeled as 220.
In the sales brochure it lists 220, but in a 1979 price list & specifications it indicates 222.
It also seems counter intuitive to have a larger tank on diesel boats that have the more efficient motors.
The sales brochure shows cruising range for gas as 235-250 miles and for diesel as 375-420 depending on the motors installed.
I also remember (not 100%) seeing a tag on someone's tank that stated 220 as useable. I also don't think Bertram would spend the $ for two molds that have such a small difference. I was hoping else with a tagged tank would confirm this one way or another.
Users browsing this forum: Bing [Bot], Google [Bot] and 365 guests
