phoenix secret props
jp here are the pictures of the "final solution" props i hope you can see from the angle of the picture the skew about 5 degrees.the cup starts from the bottom and goes around the ear and back down the other side about half way.whey beyond a # 5 cup.i have slowed the boat down to 7/8 foward 220rpm under the pin she will run 31.6kns loaded to the snot.you name it i have it onboard and 26 gallons of water with heater,ice in kill box,canyon bound for overknighter and yes the BBQ for steaks at 3am.
no problem harv for you i will personally go to my prop maker to make exact duplicates.honest it had to be 24 or more attemps with other peoples props (don`t tell them) harv.i wanted to show you a stock pair of dyna- quad for comparison.the four blade has advantages also.if you build on a bahia- mar without tower i would not need the skew.that bridge is like a sail 90degrees to the wind,and has a dramatic effect on prop design.before you start anything on the boat lets talk about balance.i am going to new york boat show dec.14.hope we can get a crew together.
yea i know and i didn`t tell harv he had better stay friends with charle in freeport,and waterk in montauk because after i play with the injection pump,exhaust and fuel delivery he will have to go to the fish market and buy fish because thats the last stripe bass he will ever see.the best i can do is 4.8 knots with one engine against the current with a 5gallon pail dragging in the stern and docking will be a new experiance at 5.5 knots!!!!
We're just fine with the 4 blades on the boat. Doesn't make much sense to play with wheels for us. The boat still has the original shaft angles so we are pretty much set with the set up we have. Anything faster than the boat is now and the bow will start to come over the top. If I remember correctly you had leveled the shaft angles, correct?
Regarding idle speeds. In the spring we fish a 20x26 w/#5 cup 3 blade. This keeps us at 3.5 with one in gear. I retuned the spoons to run this fast and it works well. Think next year I'll put those wheels on for the fall as well, can't get much below 4.1 with the 4 blades @ 20x25 w#3 cup and this is a little to fast.
Well have a good show I'll be on Long Island in a few months doing the Canyon Runner Seminars again, tis the season.
Charlie taught me how to drift for stripers. Besides, wouldn't trolling valves make a difference?bob lico wrote:yea i know and i didn`t tell harv he had better stay friends with charle in freeport,and waterk in montauk because after i play with the injection pump,exhaust and fuel delivery he will have to go to the fish market and buy fish because thats the last stripe bass he will ever see.the best i can do is 4.8 knots with one engine against the current with a 5gallon pail dragging in the stern and docking will be a new experiance at 5.5 knots!!!!
Harv
jp the only reason i posted this picture was because you and a few pm. ask to see a prop shot when i put phoenix on the hard.i assume "return the spoons"has something to do with playing with the sliding weight on the bunker spoons.i have no idea what that means!!can you really troll for bass at 4.8 knots?sometimes i am lucky enough to fool a couple of blues on a unbrella rig at that speed but bass i have thown everything but the sink trying to outwit a bass perhaps if a wahoo was suicidal and ran that close to the mainland i would have a chance.
yes harv you could use a trolling valve. you only need one,but you have to be smart enough to do it BEFORE the cockpit floor goes down or lose 150lbs of weight and coat yourself in lard.foutunatly i have alot of friends who offer their boats.
incidently jp phoenix shaft angle is 12- 1/2 degrees i would need 10 pages of posting so lets not go there.very,very complicated you must take entire driveline into consideration.rear of oil pan is 1" off bilge.
buju i fail to mention the differculty drilling multible 1/2" holes in a zig zag pattern for the "U" shaped beds for the engine mounts.there is a west german firm that makes drill bit similar in looks to a regular masonary bit but it is for hard metal.you can drill thru a metal file (as seen at the boat show)like rockwell 62 for you machine shop people.anyways there is also a cross piece on the main bulkhead to interlock both stringers.all welded and power coated white.the f-14 tomcat has been removed from combat and replaced with the fa/18 .the f-14 was made on long island.
I understand all that, but what I'm askin is:the f-14 tomcat has been removed from combat and replaced with the fa/18 .the f-14 was made on long island.
How did you get your hands on it?
Was it up for public auction?
You know a guy with access to decom'ed military stuff?
Errr what?
funny you should show that.about two years ago i was given the wish of my life.i must tell you the ship just return from iraq and was offshore around new jersey.i can`t tell much more but here i was 10' from a f-18 super hornet on takeoff will avator crew (green shirts) commarder took off with after burners as he would with full combat armament -gone in 2 seconds!!! docked in virginia after 3 day cruise.what a blast even ate in the forward mess with crew.oldest man on board by far took 6 avators home and wife cook up 10 course meal before cruise (docked in ny).they were at war for 7 months it was the least i could do .
Users browsing this forum: No registered users and 85 guests
