Air Conditioner
Air Conditioner
Going to put A.C. in the boat this year. Thou`s of you who have done it, what`s the best location for the unit? How many BTU`s, and which is a good unit. Was thinking under the foward seat in the cabin. Boat is a 31 FBC. Anything I should know? Thanks in advance. Russ
I put a 12K BTU Cruisair under the forward seat in the cabin, with an outlet on the dash going through the hanging locker. I had to add an outlet into the v-berth, otherwise the temp. difference between the cabin and v-berth was alot. Real easy install. I like the unit in the cabin, as its quieter there when I'm sleeping.
I live in MD where it can be in the hi-90s alot in the summer. I can still turn the cabin and v-berth into a meat locker when its like that--12K BTU is plenty.
John F.
John F.
I put a 16k unit in my FBC, under the seat forward of the port aft window. plenum is outbord in the port hanging locker with 2 4" ducts to the galley/salon one 2' in the head and one 4' to the v berth Brrrrrrrr. Ocean breeze unit manufactured in Stuart, all stainless works great and well priced.
Bill
Would have been under the sink of the starboard side.
http://www.seanile31.com/Site/SeaNile_During.html#5
http://www.seanile31.com/Site/SeaNile_During.html#53
Outlet in the v berth on starboard side, one above the fridge and one in the head. 16,000 btu
--JK
--JK
- MikeD@Lightningshack
A/C Location
I removed the shelving in the head and placed a 12,000 BTU Ocean Breeze Unit in there.
One vent in Birth, One on top of galley. Of course I needed to put a big return vent in the bathroom door. I think it is 12x12 teak.
Fits great, works great... Keeps it as cool as I want at night, on 90 plus days it doesn't make it down below 75 however. Night no matter what temperature it is never a problem. Summer sun on south facing black canvas windshield is tough to overcome.
It has electric heat which is great in the winter time, I went with electric because it works when the boat is high and dry and I am on board tinkering around. The electric heat comes up a little short in anything below 45 degrees. On a windy 27 degree night like last Saturday, my brother stayed on board, he complained to me that the heat wouldn't get it above 55F.
I was actually impressed it did that well!
better than sleeping in your car I guess.
mike
mike
72 FBC - Cruisaire 12K under galley counter with outlets in salon and v berth. Works fine but a 16K would be better way down here. Have reverse cycle heat and it will run you out no matter how cold outside.
Tip to remember is that the standard a/c pumps won't self prime unless the pump itself is below the waterline....a B31 rises up so high on the lifting strakes it can be a problem....I had the problem with the pump losing prime at speed in rough seas and solved it with a huge Jabsco flexible impeller pump, but it does make some noise when it kicks on.
- AndreF
Mine gets so cold I have to put cameras and bonuculars outside or else they will be fogged up 'till noon.
1981 FBC BERG1883M81E
Users browsing this forum: Bing [Bot], Google [Bot] and 214 guests
