Max Wax on my running gear
In Memory Walter K
Post by In Memory Walter K »
At the beginning of this season I applied a good coating of Max Wax on my running gear to see how it acted as an anti-foulant as the spray clear stuff was now illegal. Just had the boat hauled and have to say I was pleasantly surprised how clean my shafts and props were. Any barnacle growth was minimal. Anyone else try it this season? Walter
dougl33
Post by dougl33 »
Walt,
I had asked UV about using it for that kind of application back when he was selling the stuff.
If I remember correctly, the results were not great so I abandoned the idea. Based on your results I may rethink.
What exactly did you put it on? Shafts only or props too?
Regards,
Doug L.
In Memory Walter K
I masked off my shaft zincs and sprayed on several coats of Max Wax on them. It's yellowish. Sprayed the props too, but they could have had some residual clear anti-foulant on them from the previous year. I know the shafts didn't as I had wire brushed them very well. On haul, both looked about the same. I was surprised. Walter
randall
Post by randall »
you had better luck than me.....but i think the water in clearwater might be more condusive to those mini barnacles than montauk.....wanna pull the skiff this afternoon?
In Memory Walter K
I called earlier-I'm ready any time now.
CMP
Post by CMP »
I had similar results to Randall-no joy...
CMP
Raybo Marine NY
Post by Raybo Marine NY »
geography and usage plays a big part, what works for some is not always the same for others
Harry Woods
Post by Harry Woods »
Walter,
This is my second year of using Max Wax on my shafts and wheels. It has significantly reduced growth. The little that was on the shafts came off with a scotch brite pad. Also works great on transducers.
Harry
randall
Post by randall »
Raybo Marine NY wrote:geography and usage plays a big part, what works for some is not always the same for others
thats the answer....i think keeping the boat near the ocean with a good tidal flush everyday worked better for walter then my boat in an almost land locked and quite small and shallow "creek". even though they were only 10 miles apart.
Capt. DQ
Post by Capt. DQ »
It did not perform well at all on my shafts or wheels. Located in a bayou about 7-miles from the Gulf of Mexico.
R,
DQ
"IN GOD WE TRUST"
dougl33
Post by dougl33 »
How much does this stuff cost? Is it cheap enough to do a trial and error sort of test?
Regards,
Doug L.
JP Dalik
Post by JP Dalik »
Prop Speed and be finished with the "maybe it works maybe it wont"
It cost money but then again things that work normally do. Get together with a buddy and split the cost. The stuff works like magic dust.
gplume
Post by gplume »
I'm with JP...Propspeed....nada growth, and my part of the bay(Narraganset) is generally vey bad for growth
JP- My first year with it. Do I need to reapply every year? Howabout the primer? Or just topcoat?
Giff
randall
Post by randall »
what is it?
Buju
Post by Buju »
http://www.propspeed.com/index.html
I saw a really small kit of it for sale in my local W.Marine the other day... didn't look like something they stock, more like a special order that was never picked up...
Brewster Minton
Post by Brewster Minton »
I used Pam with butter and it worked great. I did use 2 cans. Three coats over three days.
JP Dalik
Post by JP Dalik »
Giff,
Recoat depending on how it looks. Might be able to get 2 years out of it if your not using the boat a thousand hours a year.
Users browsing this forum: Bing [Bot], Google [Bot] and 122 guests
