Removing heavy build from teak boards.
I need to remove the equivalent of 25-30 coats of varnish (about a 1/4" thick- actually acrylic urethane) off of some nice covering boards. The boat is in the water.
First thought was to tape off the gunnels at the rubrail with long mask and visqueen, and suspend the visqueen vertically (to contain the particulate) and hit it hard with 36 grit on the RO sander... but after trying it, at that rate, I'll be there until '09.
SO I'm playing with the idea of a pad on my 7" grinder, and using the gold (mirka?- with the bulldog on the back) abrasive sheets... Problem is, in the past, under any significant load, the grinder shoots the discs off at a high rate of speed...To remedy this, I was thinking of using 3M 77 spray adhesive on the pad and paper.
Then there is also the inherient danger of using a 7" grinder, if it "gets away" from me, for even a second, can easily remove too much and gouge. Allthough I can use, say 80grit to lessen that risk, and can rapidly "feather" the trigger on the grinder to avoid full rpm's.
Annnnd I do plan on following up with 60,80,120,then 220 on the RO sander to smoooooooove it out before re-coating
So, question is:
Is there a simpler method I'm missing? I want to stay away from meth.chlor. alltogether- too much danger of splatter on adjacent surfaces.
Has anyone had success with the mirka sheets on a 7" grinder in the past? A variable speed grinder would be great in this case, but that aint what I've got.
So, question is:
I think the heat will just load up the 7" Mirka discs. Have you thought of trying to use a cabinet scraper?
Al
http://www.leevalley.com/wood/page.aspx ... ,310,41069
If unfamiliar with scrapers, this holder will help.
http://www.leevalley.com/wood/page.aspx ... &cat=1,310
Al
NITES OFF
1978 B33 FBC
Al
1978 B33 FBC
Al
I use Mirka Bulldog 5" pads on my DA down to 80 grit on metal all the time without trouble. Maybe if you went to a hook and loop pad it would stay on better. There are a number of non-methel based strippers out there that you may want to try. The main thing is to avoid staining the wood with them. How about getting the bulk of it off away from any painted surfaces with a heat gun and then sanding near the painted surfaces?
Thanks!
Here is a link!
http://www.fein.de/fein-multimaster/us/en/main/
With the tool I was thinking...
http://www.fein.de/fein-multimaster/us/ ... rings.html
With the Rigid stopping knife.
I have found many, many uses for mine...
Here is a link!
Thanks guys, I went ahead with the 7"grinder and it worked out great.
Took a llittle over two hours, and only went through 5 mirka discs.
The 3M spray adhesive made a huge difference, didn't shoot off a single disc. I was a little concerned about it being hard to get ea. disc off- but the friction from grinding kept the adhesive tacky, and changing them was easy.
Also wouldn't recommend anyone just taking a 7" grinder to their covering boards without practicing... could get ugly real quick.
Immediatley after beginning this thread, I went out into my yard to "practice" on some scrap teak, mildewed patio furniture, and a old swim platform...Once you get dialed in with working the heavy grinder delicatley it works great. I did end up with one small gouge on the transom- which already sanded out during the 60grit with the RO.
The visqueen "containment" worked great also. I'd estimate that 95% of the dust remained in the cockpit area for me to vacuum up.
testing it out
ripping it up
all cleaned up, until tomorrow...
testing it out
ripping it up
Dug,
Yep, I'm familiar with the fein. Very cool infintly adaptable tool. But I don't have one... and I kinda wanted to stay away from scraping on this one, as the teak is a bit softer than the material being removed.
Lobsta,
I haven't ever seen, or used one of those. And beleive me, I've done my share of scraping- might have to look into that for future applications.
Thanks again...
Lobsta,
Thanks again...
the problem i encountered is when i built my covering boards i should have done more homework.i wanted to do the job with no bungs so i used 316ss screws and fender washers from under the gunnels after laying the covering boards in wet epoxy.if i was to removed the finish with 60grit somehow i am sure one of the screw tip will come thru so i only use teak oil instead of varnish to prevent a disaster.my covering board are full thick 5/4" or 11/4" as others refer to it.how were those covering boards attach to the gunnels?? i don`t see bungs
Randall,
Planer is a great idea... I don't have one, but would've considered buying one for the job. I was pretty apprehensive(rightfully so) about taking the big grinder to it. Allthough, there are a lot of subtle curves and angles where the planer wouldn't work as well. But for the majority of it- great idea... next time.
Love your boat.
I'm not sure how the boards are attached on this boat. I'm thinking they're just epoxied, because I couldn't seem to find any screws under the gunnels. Personally, I think that oiling your boards is the only way to go.
This is the second time this year I'm refinishing the boards on this boat. First time was this spring, when I scuffed up the existing finish and added four coats on top. Then over the coarse of one of the tropical storms this summer, his canvas top kinda came loose and the snaps scraped the crap outta the transom board. Only way to make it look acceptable again was to take it down to bare teak and start over...expensive... if he had oiled boards at that point, it would've been as simple as lightly sand & re-oil. I keep on trying to persuade the owner to let me oil them- but he's in love with the high gloss look... oh well, job security.
Now, I've gotta get over there and do the toe rail, 9' pulpit, dinghy & epirb stands, window frames, and the entire helm/flybrige area- whew... fun in the sun.
Love your boat.
the problem i find with gloss on cover boards......its a bad place to slip. plus matte is far more forgiving. i dont think there is any surface curve so radical a planer wouldnt just glide over.....its how they shape surfboards. plus you can control the depth of cut . i am however just making this up as ive never tried to remove a quarter inch of finish.
nice work
nice work
buju thank you for the compliment on the boat. when i built the covering boards i copy the double splice on the stern courners from a buddy davis but i had know idea what i was getting into trust me it looks alot easier then it is due to the coupound miters.the transon has a angle to it in addition to the miter angle.i used pine 1"x12" until i got it right.also i wanted the covering boards to completely cover the gunnels so i had to make strips of wood encased in epoxy to built up the gunnels to the height of the inside lip on the gunnels.i use a entire lenth teak spline instead of biscuits to put pieces together.alot of labor but i love the results i have never touch them with sandpaper just use walter k method to clean.
Well, after a ton of delays and a minor surgical proceedure, all the ext. teak on the boat has been refinished. Applied 9 coats of acrylic urethane to the covering boards and pulpit. Everything else was given three coats over the existing finish. I was surprised at how much of the grain profile was showing after nine coats, but it's definatley encapsulated. Could probably sand the boards down with 120, then 220, and spray another two or three coats to loose the grain- but I'm stickin' a fork in it and callin her done.
Users browsing this forum: Bing [Bot], Google [Bot] and 15 guests
