Die, die, die
Die, die, die
I need a recomendation for a good weed control(not in grass). Most everything I've tried at the local home store is pitiful at best.
I've hired guys to dig up the soil, go thru the dirt and remove the seedlings and it still comes back.
The only thing that dies in Florida is people from NY who retire here.
I want to lay the stuff down, kill the weeds and have nothing come back for at least some months, instead of days.
Trying to save laying expensive concrete around my garage area.
If the regular "gly-phos" (ie round-up etc) doesn't do it, you might try "Brush Master", although it's more for woody type weeds.
If your weeds have little green buds on them that look like sand-spurs, it's sedge, and round-up will only bruise it....you will need "SedgeHammer".
We have a great chem company here that's great with helping to 86 any weed you might have....send a pic if you'd like and I'll run it by them
Rick
Rick
Dig it up, lay down black pastic over the whole area, cover with sterilized topsoil. Fertilizer or topsoil that has been sterilized contains no live seeds. Anything you get after that is airborne and is easily pulled out or killed. The black plastic is available in garden stores and has a one way drainage perforations. What it really does is suffocate the weeds. Walter
- Terry Frank
Funny the older I get the more I am concerned about things like water supplies.
Muriatiac acid is a good weed killer as is old Detroit engine oil. But I don't want to pour on the ground anymore.
The wife keeps telling me I'm growing up. Naw that can't be true.
Will try roundup double strength.
Off to the gun show.........
die die die
Bruce,
As I understand your post, the weed problem is in your established lawn?or Are you trying to clean up a weed problem before you plant?
Glyphosate is a systemic, it translocates to the root system, stresses the plant and kills it! for one growing season. Glyphosate is the active chemical in "Roundup" a trade name from Monsanto. The patent expired, and now can be purchased under many other trade names for 1/3 the cost.
Look for it at farm supply stores. One gallon about $35.00. Three quarts to fifty gallons of water and one quart on non-ionic suffactant, should kill most grasses and associated weeds, ie Florida Betnay, Rag Weed, Wild Artichoke, etc. But it will kill any established lawn.
If you are trying to clean up an area to establish a lawn, use a pre-emergent, like Treflan. Incorporate it into the soil after spraying, use product label for application rates, and then follow up with a contact chemical (burns the leaf structure, distroys the vascular system, kills the plant). A sure knock out contact chemical is Gromoxone. Take care with this chemical, it is strong, use label information for mixing and watch for drift. Both chemicals are not soil sterilizer, and will not have adverse effect on soil stability. Diesel fuel or burnt motor oil, sprayed on weeds will kill them, but not good for the dirt. Hope this helps.
I'm like Randall..........it's a never ending battle.......if I can get the lawn mower on top of it the mower sure better be able to chop and cut it
Round Up will work better if you add some Dawn dish washing detergent to the mix.....it works as a wetting agent and makes the Round Up stick better.
Harry
Harry
Bruce,
Interesting thread....thanks for a non-boating discussion that just about everyone of us can appreciate. I say listen to Jim Clark from South Carolina. I spent a couple of days with him a while back and drove over about 10,000 acres of plantations that he manages. His background is in land and habitat management, and he has the terrible job of looking after thousands of acres of the most beautiful natural habitat that you could ever imagine. Then again, Uncle Vic's "steam away" technique sounds pretty innovative as well.
Tommy
Tommy
Users browsing this forum: Bing [Bot] and 257 guests
