Gear ratio
Gear ratio
What is the difference between a 1:5 to1 vs a 2:1 in shaft rpm from your transmission? Thanks again.
Selecting the proper gear ratio is also dependant on which engines, rated RPM, & horse power you're coupling the transmissions to...
For example, the 320 - 330 HP Cummins 6BTA needs a 1.5:1 ratio, but the 315 Yanmar 6 LP/LY or the 4 LH needs a 2:1 ratio. Basically, low RPM engines need the 1.5:1 & high RPM engines need 2:1...
Gear ratio
Thanks Walter and Harry. one more ?. if i were to put Yanmar 315s in my 31 what is in your opinion the best gear ratio. the boat is light no gen set or things like that. I would like to see a wot of 32kts. but if possible be able to live bait on the first click.Thanks again so much.
I realize that HP "is what it is" but, doesn't torque at the shaft increase by adding reduction? I was under the impression that 2:1 gear basically doubled the torque at the prop? 1:5 added 50%, etc. and this was why boats with stepper reductions were less effected by load, or sea state.
Assuming the engine/gear combination are within reason and prop pitch + shaft rpm + slippage provides the desired hull speed.
Should I check into rehab?
Gear ratio
Cap'n Pat if you look at the time you posted and my next question that was posted you will see why I missed your reply. Thanks though.
Bruce......how did you know??Some of you guys must be using chinese calculators
[img][img]http://i147.photobucket.com/albums/r289 ... abacus.jpg[/img][/img]
Harry
Opunui,
We have Yanmar 6LPs 305hp (315hp with lower Cetane rating here) with 20 x 23 four bladed and we get 30.5knots wot regularly, but tell everyone 32 at the pub and get away with it.
Locals are getting better top speed results with smaller dia props and suggested 19 x 24s but we went for the size most commonly recommended on this site and are very happy. Massive grip on the water...idle is 6knots approx.
The most important thing is to max at 3900+ revs, we get 3940 & 3960 or so, for long engine life.
Nic
Nic
Users browsing this forum: Bing [Bot], Google [Bot] and 146 guests
