Friends diesel generator had a hard time starting then ran a minute then died. Started again then died with 10 seconds. No longer will start at all.
Filters have been changed pump is pumping fuel no fuel out the return so solenoid is not opening. Pulled the water, oil, and exhaust wire's off the sensor all check out still will not start.
Three wires going to solenoid all white no marking of + or - I assume it is like my onan 1 + for preheat so fuel pumps the fuel and + for run and a -.
Also see two leds that light during cranking in the control box looks like LED 2&3 there are 5 total. Don't know what this means no service manual. Just have owners manual which does not go far.
Unit is around a 1997 5K
Appreciate any help.
Thanks Dan
Kohler 5E07 need help!!
Users browsing this forum: Ironworker and 74 guests
