Rub rail
Bending the PVC guard rail to the transom is not feasable... Too much material to bunch up into a smooth 90º angle. You'd need a pair of female molds to even attempt it. While mitering is a tedious job, it's the only way to get a good result.
By using your old aluminum rail as a mold, you can make a pair of fiberglass templates that will at least allow you to mark out a close approximation of the necessary cuts.
Here's a fairly complete rundown on the rail being installed on "Buddy Boy"... -- PVC Guard Rail Installation --
Users browsing this forum: Google [Bot] and 40 guests
