was looking into this set of motors but wasnt sure about the gears if they will work or not a good idea
http://cgi.ebay.com/ebaymotors/Pair-Mer ... dZViewItem
was also looking at a used set of 454s with Velvet Drive 2 to 1 Straight Inline.
one thing i know nothing about is the gears any help appreciated
questions about transmissions
Re: questions about transmissions
Give me a call at 917-714-38711962 31 wrote: was also looking at a used set of 454s with Velvet Drive 2 to 1 Straight Inline.
Harv
ZF 630 gears will work fine in a 31 and will take up to 325hp on diesel.
Yanmar uses those gears on the 6LP 315hp.
8 degree down angle on standard setup.
The BW velvet drives are an inline gear and will require the engine to be tilted. Which is why most older gas had thick wedge plates under the carb.
New gas and diesel are limited to around an 5 degree angle which makes using the old velvet drives not practical.
Users browsing this forum: Google [Bot] and 428 guests
