Teak care
Teak care
Alchemy is supposed to launch this coming week, and all the spring polishing is done for the fiberglass. She looks pretty good so far. What I have left is the Woody Wax on the aluminum and then the annual teak triage.
I am a lifelong devotee of Tip Top Teak oil. This product is not available anymore so it appears. I am inconsolable!
After years of trying products of varying types, I have a set routine of set products that I know work for me. In short, they yield the results I seek, and I know how to use them.
Tip Top Teak is one of those products. In fact, the smell of that oil going on is one of those smells of summer for me... sick, isn't it?
So the question is then, what do I do?
Do I leave it blonde? And then every bit of gook and gunk will show? And there is some special concoction of 50% water and 50% ammonia or vinegar or something that many in southern climates use to keep the deck looking great! What is that mix, and how well does it work?
Or do I try another brand of oil? Any luck with Star brite?
I am not going to use cetol, or semco or any of those. Bad luck in the past, and no way no how.
How do you handle your teak if you have it? Thoughts anyone?
...also, for cleaning / resurfacing all I do is use a bleach & water mixture. About 2/3 water, 1/3 bleach.
1) wet the teak and surrounding area with water
2) apply water/bleach mixture with a pump garden sprayer
3) scrub the teak across the grain with a med bristle boat brush
4) re-apply water/bleach mixture and let sit for a few minutes ( don't let it dry)
5) scrub with brush across the grain again
6) rinse with hose
let it dry overnight and apply oil the next day
6) rinse with hose
Dug,Dug wrote:Patrick, what is the 50/50 mix again? Water and Vinegar? I can't remember. It leaves that nice blonde look...
For cleaning I use 2 quarts of household sudsy amonia with 1 tablespoon of concentrated liquid dishwashing soap such as Dawn. For brightening, a 1:1 solution of household bleach & water. I use only a scrub pad, rather than a brush, to avoid digging away the soft grain of the wood when wet...
Dug, you ahead of me. I just got started this past weekend.
I'm so far behind I took a shortcut on the teak, for what its worth I just powerwashed the teak and it came out pretty good, especially for somthing that sat out in the elements all winter.
Amazon teak oil has been the brand of choice for me for some time.
sudsy ammonia then a wood brightener (the teka part B or even the brightener crystals work fine)
I found that bleach leaves the wood a little greyish and the brighteners allow a blonder look.
Same a Capt Pat said. A scrunge pad soft bristle brush (blue or yellow head) or even a mit if it nots to stained.
Linseed oil is your friend.
