fuel lines
- JohnCranston
fuel lines
My mechanic likes to use high pressure, blue rubber I think, web reinforced lines with crimped on threaded brass fittings. Is this overkill? If not, where can the brass fittings be found? He says that none are available locally and that he usually reuses existing ones, or gets them from Bertram. I dont know if my barb fittings can be removed from the tank, I'll have to check it out.
Much thanks.
Much thanks.
We have Moreland hose and several others. You need to search for Hydraulic hose suppliers in your area, John. They usually supply all types of hosing. I did a quick search for Texas and found about 20 places in the Brownsville/Dallas/Galveston triangle. I am sure one of them should be able to help.
They are usually very helpful. Good luck and enjoy the weekend.
- JohnCranston
John: Find your local Parker-Hannifin distributor. They will have or can get you everything you need.
http://www.parker.com/portal/site/PARKE ... nextfmt=EN
- JohnCranston
John,JohnCranston wrote:Guys,
There's plenty of places to have the hydraulic lines put together, but the problem is finding the brass fittings.
Thanks.
Just about any good hose shop will get the brass fittings if that's what you specify. They may not stock them but can get them, most likely from WW Grainger...
- JohnCranston
Plenty of places in Houston with the fittings. The fittings are the same as used by commercial divers on compressor whip lines, etc. If you have a local commercial dive company call them and ask them where they get their brass JIC fittings.
Users browsing this forum: Google [Bot] and 77 guests
