I've just purchased a 1987 50 Bertram and am going to put a new anchor on her. Have a bow pulpit that comes across top of the anchor so I think newer styles (e.g. rocna, manson) won't work. Have been looking at a 55lb delta but wonder if I should be looking at a Bruce?
Also curious as to thoughts about anchor weight, is the 55lb delta the right size or should I go up in weight?
Thanks very much
Best Anchor
I've had a Bruce & now I have a 35 lb Kingston. (Delta knockoff) In rocky areas the Bruce was easier to get caught in rocks & then difficult to free up. On both of them I've also snagged lobster trawls in 100' water. (Lobster trawl could have 5 > 10 traps on a trot line) With all that weight I had a heck of a time lifting the trot line off the fingers on the Bruce. On the Kingston, once the anchor was pulled up to the boat, I just had the Admiral bump the boat into fwd & I was able to just slip the trot line right off. I also think the Delta style sets a little easier.
If you anchor out a lot in deeper water & have lobster trawls in your area that is something to think about. Of course you could always just cut the gear loose. I figure these guys are trying to make a living, so I don't.
Al
Al
NITES OFF
1978 B33 FBC
Al
1978 B33 FBC
Al
I've bottom fished for years here in the Northeast (for a living and recreationaly) in boats from 18 to 65ft. I've always had great success with the Danforth style anchors. Whether it be the expensive Fortress anchors or the standard Danforth High Tensile anchors. The biggest secret is the length of chain in front of the anchor. The secret to setting the hook is always having enough chain in front of the hook and plenty of scope.
Have fun and good luck
Users browsing this forum: No registered users and 131 guests
