Mad Mariner Article
Mad Mariner Article
If anyone is interested this was in Mad Mariner. Unfortunetly the pictures did not come out.
http://www.madmariner.com/vessels/power ... _051108_VP
Bertram 31 Review
Updated May 13, 2008
Review Bertram Links Current Prices More Reviews
Updated May 13, 2008 Once An Innovator, The Bertram 31 Is Now A Classic
In 1960, Miami sailor, powerboat racer and yacht broker Dick Bertram entered the 165-mile Miami-to-Nassau offshore powerboat race with an innovative Ray Hunt design called Moppie. In eight-foot seas and 30-knot winds, Bertram blew the competition away and won the race in record time, two and a half hours ahead of the next boat to finish.
Bertram became convinced Hunt's prototype represented the design of the future. He made a mold of the hull, and in 1961 launched Bertram Yachts with the introduction of the Bertram 31 Sport Fisherman. After more than 1,800 hulls, regular production of the Bertram 31 ended with the 1983 model year. In 1986, Bertram produced 23 "Silver Anniversary" versions of the 31, with oak interiors and custom hull striping, but none have been built since.
Overall Length 30.58 Feet
Maximum Beam 11.17 Feet
Maximum Draft 3.08 Feet
Displacement/Weight 10,600 Pounds
Fuel Capacity 170 Gallons
222 Gallons after 1972.
Water Capacity 18 - 60 Gallons
Speed Range 23 - 32 Knots
The Bertram 31 was a radical departure from mainstream thinking about what made a powerboat perform well in a variety of conditions. It's most unique feature is what has become known as the deep-vee hull form. Typically, planing hull powerboats had fairly steep deadrise (the angle of slope from the hull centerline to the chine) in the forward sections that gradually flattened to about a 5- to 10-degree angle at the transom. Designers felt that if the deadrise were further increased in the after sections, a significant increase in horsepower would be needed to raise the boat onto and maintain a plane.
Hunt reasoned that by incorporating lifting strakes along the bottom, he could provide adequate lift without requiring excessive horsepower and, at the same time, significantly improve performance and ride. The Bertram 31 and its prototype were designed with a remarkable 23-degree angle of deadrise at the transom. There were three lifting strakes on each side from the keel to the chine. The concept worked, and Hunt's deep-vee hull has remained the standard for performance-oriented, monohull boats for more than 40 years.
The 31 actually measures 30 feet, 7 inches in length over all; has a beam of 11 feet, 2 inches; a draft of 3 feet, 1 inch; and a displacement of about 11,000 pounds.
It may sound trite, but they just don't build them like this anymore. In my opinion, the Bertram 31 is one of the most robustly built boats of any size or material. This likely explains why many people are so willing to spend many thousands of dollars to renovate and repower older models. Hulls are constructed using fiberglass cloth, woven roving and fiberglass mat in combination with plastic resin. Layup is more than ½-inch thick on the bottom near the centerline, and even at the sheer, it measures in excess of 3/8 of an inch.
Decks are also a solid laminate of fiberglass and resin and measure ¼-inch thick or greater in most areas. The deck and hull are joined on a narrow outward flange with mechanical fasteners every 4 inches. There is very little use of core materials. Where core is used, it is in combination with substantial fiberglass coverings.
Because the design of the 31 includes tumblehome (narrowing of the hull at the sheer) towards the transom and a molded-in spray rail at the chine, these boats had to be built in split molds that could be separated after the hull set. The additional finish work on the parting line of the mold added to the cost of production and likely helped lead to Bertram's decision to discontinue this model. The Bertram 31 is one of only a few production boats I have come across in my career that never had any significant structural failure, even on boats that endured very tough service.
As these vintage photos show, the Bertram 31 has been around awhile. Beginning in 1961, more than 1,800 hulls were built.
Realizing early on that demand could be rather limited for a spartan 31-foot fishing boat, Bertram soon expanded its line to include a variety of models built on the same proven hull form. For the most part, differences in models were very subtle. The Flybridge Cruiser is nearly identical in profile appearance to the Flybridge Sport Fisherman, although the cabin area is closed off with a bulkhead and door at the after end of the hardtop. The Express and Bahia Mar models are slightly different in appearance in that they have open helm positions and no fly bridges.
Many 31s have been highly customized over the years with the addition of towers and custom fly bridges, but there is no mistaking the distinctive Bertram 31 sheer line and hull form.
Make no mistake; the Bertram 31 is, first and foremost, a fishing boat. In fact, it is one of a few small boats that can still be regularly found competing in bluewater fishing tournaments. This does not mean the 31 can't be an efficient, although somewhat spartan, family cruiser.
Original equipment for all models includes V-berth accommodations, a marine toilet and minimal galley facilities. The Cruiser and Sport Fisherman models have a dinette area that can be converted to a "cozy" double berth. The cockpit, however, is where this boat shines. There is more than 110 square feet of space, which accounts for more than half the space aboard, and there is plenty of room for a fighting chair, with room left over to get around.
Most Bertram 31s were originally powered by two 330 horsepower Mercury Marine inboard engines, a combination that provided a respectable cruising speed of about 26 miles per hour and top speed of around 37 miles per hour. Over the years several models of General Motors, Caterpillar and Cummins diesel engines were offered as optional power. The diesel engines generally yielded slightly less speed but improved cruising range.
The engines are located near midship in insulated, raised boxes. Engine boxes are completely removable, allowing excellent access for service to all parts of the machinery. Fuel capacity of the original Bertram 31 was 170 gallons and was increased to 222 gallons with the 1972 model.
The Bertram 31 has become legendary for her ability to handle big seas in relative comfort and safety, but another attribute that is absolutely necessary for a successful fishing boat is maneuverability. The 31 is easily controlled whether in head seas, following seas, fighting a fish or docking at a marina – yet another reason for her loyal following.
As is the case with most boats, the Bertram 31 is not without her little quirks and imperfections. The ride can be, and often is, a wet one. The freeboard forward measures only about 44 inches. Although there is a molded spray rail at the chine, there is little flare at the bow, and powering into even a moderate chop of several feet can result in a wet ride. And despite the advantages associated with the 31's deep-vee hull form, there are some disadvantages, too. One is that the form provides little buoyancy at the chines. Because of this, the 31 tends to roll from side to side considerably in a beam sea, particularly at slow speeds or drifting, a condition that can be somewhat disconcerting to some people.
As testament to the enduring popularity and lasting value of the Bertram 31 Sport Fisherman, which cost just under $20,000 when it was introduced in 1961, the current market value for a 1961 model actually exceeds what the boat cost when new. In fact, a substantially restored and repowered early 60s Bertram could sell for considerably more.
There is an active Bertram 31 Owner's Club with nearly 1,000 members nationwide. It publishes a newsletter and helps members locate hard-to-find parts and repair manuals. For further information you may contact Bertram Owner's Club, P.O. Box 2324, Seal Beach, CA 90740 or Fax (562) 598-8715.
Some have argued the Bertram 31 is the best powerboat ever built. I would argue that the matter is much too subjective to ever pick one best boat, but the Bertram 31 surely ranks near the top of my list for this size and class. If there were a hall of fame for powerboats there is no doubt this would be one of the very first inductees.
Jack Hornor, NA is the principal surveyor and senior designer for the Annapolis-based Marine Survey & Design Co.
Bertran31.com Website
Bertram 31 Specifications and sketches
Original Bertram 31 Owners Manual
Bertram 31 Forum
Original Bertram 31 "Moppie"
Worton Creek Marina Bertram 31 Page
Cabrera Yachts Bertram Specialists
Video: Bertram 31 Repower
Review: YachtSurvey.com
Review: Yachting Magazine
Bertram 31 Screen Saver
NADA Guide Pricing Information
BUC Used Boat Price Guide
BoatU.S. Valuation Service
SellYourBoatNow.com
BoatU.S. Consumer Protection Database
BoatHistoryReport.com
nic
Re: Mad Mariner Article
Post by nic »
I love reading that story. When he talks about construction one thing he fails to mention is that the fibreglass is hand laid, the beginning and end of quality construction.
Now, a question that has been bugging me for years:
Horner wrote: Hunt reasoned that by incorporating lifting strakes along the bottom, he could provide adequate lift without requiring excessive horsepower and, at the same time, significantly improve performance and ride.
This was the innovation, the lifting strakes. The deep vee, or long vee, had been around for decades as a design concept, Hunt's lifting strakes made it work.
In the 1970s I remember talking to old Jimmy, a WWII vet who lived on his boat at Manly who said he served in Queensland with Ray Hunt during the war...he thought Hunt was an Englishman, (New Englander?)...and they worked on flying boats, Catalinas or Sunderlands, which were slow to get out of the water as they took off...until Ray Hunt added lifting strakes. Jimmy recalled he was a difficult man to work with and laughed that they all called him Ray Hunt the "rude name"....which is a lot of detail to go into if it was all made up.
Does anyone know whether Ray Hunt was in Australia during WWII and if this story is true? Naturally, I'd like to think it is.
Nic
Hornor wrote this article about 10 years ago, and it still gets reprinted every couple of years somewhere... One of those "I'm lazy, so I'll just republish someone elses work" type articles. At least Mad Mariner included some up to date links & listings to go along with it.
But, it'd sure be nice if, when someone republishes Hornor's review, that they would also add a comment that the "Bertram 31 Owner's Club" in California went defunct shortly after Hornor wrote it. Guess that'd get into the "Too much work & research" aspect being lazy...
Lot of B31 Owners got burned by joining that club & only a decal & maybe a couple of crappy newsletters to show in return for their dues.
In Memory of Vicroy
Post by In Memory of Vicroy »
And some of the article was lifted from Pescoe's survey article.
Jareb
Post by Jareb »
The article is like Steve Knauth's version in the August 1998 edition of "Soundings". This was also a good one, if you get the chance to read it.
Pat,
When the Times represents the journalistic pinnacle of the profession, what do you expect from anyone else?
Really shows the integrity of that publication to reprint articles with outdated information.
And prey tell what boat doesn't?
nic
Post by nic »
Well, there is only one thing to be done about this.....write the definitive article about the Bertram 31 and release it to all these publications so they can re-publish it for the next few decades...any takers?
What happened to that guy who posted he was writing an article and wanted owners' stories a while back?
Nic
Didn't think this would stir the pot up. I knew it was old, especially still refering to the Owners Club. I think the guy that used to run that now writes for Power and Motor Yacht.
Maybe if these guys were smart they would just interview Capt. Pat and Bruce and then write something new.
Lazy trumps smart...
Users browsing this forum: Bing [Bot], Google [Bot] and 47 guests
