Fuel filter restriction gauge ?
- AndreF
Are these worth installing on my RACOR?
1981 FBC BERG1883M81E
If you mean the pressure gauge that replaces the T-handle on top, They can be very helpful if you have an air leak or clogged filter. I had a hairline crack in the bowl base that was invisible because of where it was. My engine would start up, then die in a few seconds, after which it took a lot of cranking to start up again. Once started, all was fine all day long. Then, the next time I came back to the boat after a day or so, it was the same thing all over again. I changed the fuel line, lifter pump, filters and gaskets all to no avail. It wasn't until my son saw bubbles in the Racor bowl when I was cranking that we found the problem. Had a gauge been on that filter, we would have seen the loss of pressure much earlier. Walter
- AndreF
I'm having that exact problem, Walter, and wondered if that vacuum gauge (where the "T" handle goes, as you said) was worth it when I replace the bowl, thanks Bruce. I need to check clearance, Clarence, as the gauge sticks up alot. Around $60-$70 each.
Users browsing this forum: Bing [Bot] and 54 guests
