Need help from you guys on this one, Have the thru hull that has the T handle on the inside in the bilge. Need to replace and I believe is an 1-1/2 in size, any suggestions where to get one , Am ready to put boat back in the water is the last thing
Thanks Captain Bill
Charleston SC
Thru hull
Bill,
Depending on the size that Bertram installed in you boat, it will be either a 1/2" or 3/4" NPT. Probably 1/2"... You should be able to find a square head pipe plug in bronze at Boat USeless or Worst Marine, (maybe without a T handle). Ask for a garboard drain plug.
Users browsing this forum: No registered users and 41 guests
