Soda/Sandblasting
DRIFTER31
Soda/Sandblasting
Post by DRIFTER31 »
Does anybody know if a regular pressure pot sandblaster will strip the paint off the bottom if i use extra fine glass beads[180-320grit]?
Ihear soda uses a different kind of blaster. Thanks Troy
If you want to keep the repairs to the bottom to a minimum go with soda. Anything else may take it down to far. Take it from someone who spent hours trying to find all the little pin holes that went through to the mat after the bottom was Sand Blasted. Soda is kinder but you should think about putting on a barrier coat when you are done.
DRIFTER31
Post by DRIFTER31 »
Thanks Rawleigh....That little adaptor is exactly what i need to do the job. Ask and ye shall receive @ Bertram31.com. Troy
Let me know how it works!! I've been keeping an eye on it but haven't bought one yet. Good luck!
Marshall Mahoney
Post by Marshall Mahoney »
I experimented with walnut shells before I went with soda. Harbor Freight sometime has bags on sale. They stripped the paint well. I think that the glass beads would be harsher and leave an anchor pattern. Dust may be an issue for you depending on where you are doing the work.
randall
Post by randall »
like marshal i used walnut shells....worked well but patience is required. a friend did his with sand at low pressure......an interesting concept. the soda do- hicky is appealing
Users browsing this forum: Bing [Bot] and 150 guests
