scuppers
Bill, check these out. They kept the "Crowsnest" afloat with Me, Harv and Diesel Doug in the cockpit.
http://www.mysimon.com/9015-11031_8-34207838.html
- bobfioresi
scuppers
I bought the white rubber material with the diamond raised feel on i t ,same as the original on my 31 from boat owners warehouse here in fla no is 1800boats-99. They had it last year. If you want it e mail me if you can't locate it and i'll go get it for you. I can mail it to you. I have no idea how much it costs. but not expensive. bob
In some cases the Seastops hang due to the arch in the transom (as noted). I have found that they can be modified by "rounding off" the top edge of the flapper plate and reducing the corner pin OD on the flapper plate. The bind often occurs as a result of the flapper plate having tolerances that are too tight, a lttle work with a file on the flapper plate and they typically free up and work fine on curved transoms....assuming the curvature is not excessive.
Have an extra pair of white Sea Block scuppers (like the ones in John D's post) that I will send to anyone needing them. They will fit a hole maximum of 2" x 5". Send Capt Pat a little something and when he tells me he is in receipt they will be UPS'd to you.
Users browsing this forum: No registered users and 235 guests
