Air horn recommendations...
The OEM electric horns (AFI) on our runabout have crapped out...don't want to use the same brand due to rust issues...
Any recommendations? Electric or air.....a Kahlenberg would be nice, but at $700 for the smallest is a bit steep :wink:
Rick
Rick
I just recently picked up a deep sounding single trumpet air horn for the land yacht. It has a small compressor and works just fine. Sounds like a Big Rig air horn. Total cost installed in the van was about $250, the unit alone about $175. When I get my boat back in the water, I think I will be changing the existing horn for one of these also. Can probably be found at Strauss, Pep Boys, Auto zone, etc. I picked mine up at a van customizing center.
Harv
I was replacing my AFI horns every two years due to rusted out guts. Installed an Ongaro dual trumpet all stainless steel including the guts and it has lasted about five years now. www.ongaromarine.com/horns.htm About $200.00
Eddy G.
Eddy G.
Sounds just like what I have. I had mine mounted transversly along the front bumper. The trumpet alone is over 2 ft long. They even had to drill 2 holes through the front plastic dam to run the air tubing. It does sound sweet though.Dug wrote:Harv,
I have air horns on the Touareg. They are mounted behind the grill and sound like an Amtrak train.
I love them.
Nothing like waking up an idiot to put a grin on one's face...
Very effective. D
If you get stopped just tell the cop it was from a passing truck. I think they would be hard pressed to find my horn if they looked for it.My friends tell me not to honk it when I drive in NYC. They tell me I will get a ticket...
Harv
They have been doing a lot of construction around one of our shops. ONe day the lights were down at the far end of the busy road.
The cop was suiting up, but there was a dimwitted driver up at the intersection. I gave it a good honk to urge them along. I think the cop wet himself, as he was looking the other way.
Though it was not intended to rile him, it was really funny. I just stared straight ahead like all the others. Just another car in line.
And the dimwit got the message and moved along...
Thank god for small pleasures...
I have mine on 2 seperate switches. I can use either horn or both together. Now that's a blast. I like the look on my own passenger's faces when they hear my horn for the first time. WooHoo!!!Rawleigh wrote:You need to install a toggle switch so that you can select between it and the OEM horn! Now that could be funny!!
Harv
Users browsing this forum: Bing [Bot] and 103 guests
