BIG DIESELS
BIG DIESELS
I was in Stuart Fl last weekend--and saw a 31 blocked up on Dixie Highway--noted that it had big shafts and wheels--Knew it was a diesel--upon closer inspection noted that the hull had large bubbles in the hull to accomodate probably transmissions----i heard that rybovich used to do this-but it was a first i saw in a bertram.
No one to speak to --what the power was.
Big Deisels
Craig,
The boat you saw in Port Salerno was orginally from the other coast of Florida, It sank during one of the hurricanes, been sitting for a couple of years. It's got a pair of 370 hp Yanmars and they added a bubble(step in hull) so the engines would fit in the boxes. It was reciently sold to a guy from Italy. Boat is in rough shape, has extra fuel tanks and has large squirrel cage blowers behind each engine for air supply. Reported to have sold in the low 30's. Lot's of work to be done to her.
Big Deisels
Craig,
If your talking about the 31 on Rocky Point opposite Sailfish Marina(across from Sand Sprit Park) I don't know who owns it, never seen it off of it's lift. Been there for at least 10 years. If your in the area again give me a call (561-310-7179 cell). Bruce that guy makes you look like a Massachusetts liberal, Russ is right the guy thinks his turds don't stink.
craig the installer did not have to "wack" the bottom of that 31 to install a 370 yanmar jusy a little inginuity would make it the best power for a 31bert. zf90ivts is a two speed trans with a 12degree down angle.you could unleash that power yet idle down to 5mph.the trans. allows you to mount the engine in the stock engine compartment with stock hatch.
Users browsing this forum: Bing [Bot], Google [Bot], pschauss and 105 guests
