My B25 Sport COnvertible does not have a bow eye.
I want one for trailering purposes.
How much reinforcement do I need here? Should I lay in a couple layers of 1708 to 'thicken things up abit', back with a fitted peice of wood and glass in or simply drill the holes and fasten the eye?
Any suggestions?
Ian.
Installing Bow Eye on 1962 B25
Ian,
Cut and fit a V shaped wedge that conforms to the interior of the bow leaving the flat facing you... Should be about 2" thick at the deepest point. Epoxy that in and then you'll put a steel backing plate between the wood and the nuts. Use a hard wood, like oak if possible, but pine will work.
Users browsing this forum: Google [Bot] and 435 guests
