Gents,
I am looking at a 1961 Bertram 31 as a project boat. Is there anything I should know about the '61 models that may influence my decision to pick this or another year model?
Thanks ...\\
1961 Bertram 31?
If it is in truth a 1961 Bertram, it would be one of the earliest ones I have heard of. Find out what the serial numbers are. Mine is a 64 and is #31-382. The good news is the hull is thicker than later models. The bad news is the original chain/Cadillac steering box is useless as is the wiring, but then again, you said Project Boat, and I assume you mean it. Walter
Page,
As far as vintage years go, the early '60's B31 is the best in relation to the hull and fiberglass content. The Sportfish model has the more structurally sound flybridge bue to the over-built and more structurally designed pilasters. The only down side to the earlier models is smaller fuel tank capacity, but on the up side, there's more apparent gunnel height in the cockpit due to the deck being 3" lower.
Page,
Increasing the tank size would entail not only having the tank built, but also restructuring the deck substructure. The deck work may not be that much of an additional expense if the original plywood deck is present. If so, the deck is already on the project list. A new tank will cost from 2 - 3K+ depending on whether you opt for SS, aluminum, or vinylester & fiberglass.
A lot will also depend on how much "sweat equity" you plan on providing... Generally, DIY involvement will lower your cash outlay, but increase the length of time it takes to complete the project.
61 Bertram
There is an older (mid 60's)31 being worked on up here and the entire boat had to be gel peeled due to the alligator skin (cracks). Look closely at the body work on the boat, if you see a little alligator skin starting on the hull or superstructure you may want to pass.
The problem goes away on the 70's boats. Maybe Capt. Pat can elaborate.
Good Luck
Good Luck
Users browsing this forum: No registered users and 51 guests
