Morse Throttle Slip
tippers
Morse Throttle Slip
Post by tippers »
Hi Guys
Can anybody give me advise on how to stop the throttle levers slipping on my Morse contols.
Max revs 3000 above that they slip back to 3000,new cables installed.
Bertram 30 and 31 Express.
Skipper Dick
Post by Skipper Dick »
There should be some screws that provide friction on the leavers. Take the housing off and find them other than the screws that adjust the cable length. Don't screw them down too tight otherwise you could strip the friction application. I've had that happen. Then you have to modify the friction control. You want them to feel comfortable, but not too restrictive and definately not slipping when you take your hand off the controls.
Dick
Harry Babb
Post by Harry Babb »
I don't know if my controls are Morse or Teleflex or whatever but I had the same problem.
Since sometimes I tend to overlook the obvious and complicate things I took the entire control off and started disassembling it when I discovered that there is an adjustment screw accessable without taking anything apart.
The screw on my controls is on the handle and tightens aganist a friction on the shaft.........the best I can remember is that when you tighten the friction it tightens both the shift and the throttle.
Harry
If you don't have friction stops, try small hose clamps around the cable to pinch the jacket some. Morse makes a special clamp that does the same thing.
tippers
Post by tippers »
Thanks for all the help will try these fix`s
Users browsing this forum: No registered users and 57 guests
