01 F250 4X4?
- thuddddddd
01 F250 4X4?
Any one know what the front and rear diffs are in this truck? or wher I can find the info..
What, What
Thought the rears were corporate Ford and the fronts were built by Dana.
What ratio? My 04 is 3.73 think that's a standard gear with the 6.0.
You should be able to find axle ratio in your owners manual. It's referenced off your VIN# axle code C1 is how mine reads.
- thuddddddd
- thuddddddd
- thuddddddd
- thuddddddd
This is what I could find from home, more research tomorrow when I get to work.
Vehicle Highlights for 1FTNX21F21EB27921
Vehicle Description: F250 SUPER CAB PICK-UP 4X4
Model Year: 2001 Vehicle Model/Type: X21
Production Date: 15-NOV-2000 Exterior Paint Code: Z1
Tu-Tone Paint Code: Interior Trim Code: 9H
Gross Vehicle Weight: 08800 Wheel Base: 158
Components for 1FTNX21F21EB27921
AXLE
AXLE FRONT FWD 1:
AXLE FRONT FWD 2:
AXLE FRONT RWD 1: D271D
AXLE FRONT RWD 2:
AXLE REAR FWD 1:
AXLE REAR FWD 2:
AXLE REAR RWD: 409H
INSTRUMENT
INSTRUMENT CLUSTER 1: XC3F10849CE
INSTRUMENT CLUSTER 2:
INSTRUMENT CLUSTER 3:
CHARGING
ALTERNATOR ID: F81U10300EB
STEERING
STEERING ASSEMBLY: XL3C3C529AA
STEERING PITMAN: YC353590AB
STEERING SHAFT:
COOLING
COOL RADIATOR ID: YC3H8005BA
COOL HOSE UP ID: YC358B274CC
COOL HOSE LOW ID: YC358B273CF
SUSPENSION
SUSPENSION SPRING CODE:
SUSPENSION SPRING ID FRONT: YC355310AMC
SUSPENSION SPRING ID REAR: YC355560CA
SUSPENSION AUXILLARY REAR:
DSO
SPEC DIST CD: 48
TRANSMISSION
TRANSMISSION ID: 1C3P7000FA
EMMISSION
EMMISSION CALIBRATION: 1F719S0A
EMMISSION PROC ID: 1C3F12A650ZC
WHEEL
WHEEL COVER ID 1: 1C341A108AB
WHEEL COVER ID 2:
WHEEL COVER ID 3:
WHEEL COVER SPARE: F81A1015AA
WHEEL COVER ROAD: F81A1007MA
ENGINE
ENGINE TAG ID: BE002AA
DRIVE LINE
DRIVING SHAFT REAR ID: F81A4K145LTC
DRIVING SHAFT FRONT ID: YC3W4A376MA
DRIVING SHAFT COUPLING:
BUMPER
FRONT BUMPER: 1C3417750GFYBCC
REAR BUMPER: YC3517775DBSMAW
GRILLE
GRILLE 1: 1C348200BAYBAC
GRILLE 2:
GRILLE 3:
TRAN CASE
TRAN CASE ID: F81A7A195JD
MIRROR
MIRROR 1: YC3517683FAYGAK
MIRROR 2: YC3517682FAYGAK
FUEL
FUEL TANK 1: 1C349K007MA
FUEL TANK 2:
FUEL SEND MID ID 1:
FUEL SEND MID ID 2:
FUEL SEND MID ID 3:
WIRING
WIRING ENTITY 1: 1C3T14401PAA
WIRING ENTITY 2: YC3T14405APD
WIRING ENTITY 3: 1C3T15525BB
WIRING ENTITY 4: 1C3T12A581FAE
WIRING ENTITY 5: PM1C3T13A409AC
WIRING ENTITY 6: YC3T13A576CA
WIRING ENTITY 7: 1C3T14A005LAC
WIRING ENTITY 8:
WIRING ENTITY 9:
WIRING ENTITY 10:
WIRING ENTITY 11:
WIRING ENTITY 12:
AXLE
AXLE FRONT FWD 1:
AXLE FRONT FWD 2:
AXLE FRONT RWD 2:
AXLE REAR FWD 1:
AXLE REAR FWD 2:
AXLE REAR RWD: 409H
INSTRUMENT
CHARGING
STEERING
STEERING SHAFT:
COOLING
SUSPENSION
DSO
SPEC DIST CD: 48
TRANSMISSION
EMMISSION
WHEEL
WHEEL COVER ID 2:
WHEEL COVER ID 3:
ENGINE
DRIVE LINE
BUMPER
GRILLE
GRILLE 2:
GRILLE 3:
TRAN CASE
MIRROR
FUEL
FUEL TANK 2:
FUEL SEND MID ID 1:
FUEL SEND MID ID 2:
FUEL SEND MID ID 3:
WIRING
WIRING ENTITY 8:
WIRING ENTITY 9:
WIRING ENTITY 10:
WIRING ENTITY 11:
WIRING ENTITY 12:
Jim
1975 28 FBC
1975 28 FBC
TIMMY GOT SOME PARTS FOR SALE!!!!!!!!!!!!!!!
If you get a winch your garuanteed to never get stuck.
Had an F150 with 33's and open diffs, was a little worried it might not have enough ooomph for skipin across the corn fields to goose hunt. Got a winch, never got stuck- its the old story, if you have it you never need it.
- thuddddddd
- thuddddddd
- thuddddddd
Users browsing this forum: Google [Bot], Tony Meola and 157 guests
