Fixin to spruce up my Cummins 210
Pulling the stbd transmission will give me a chance to work on the stb engine and engine compartment this winter/spring.
In preparation I took some photos and am compiling a list of parts and supplies. Your input is welcome.
Warning: This post contains graphic images of a poorly maintained engine and may not be appropriate for all viewers.
First off, the raw water pump(s) needs attention.
In addition to replacing the impeller and o-ring, the book says to replace the wear plate.
My yard guy is recommending I replace the cam, what do you think?
Here's the whole left side of the engine.
Those brown stains are from a since-fixed fuel leak.
I'm thinking a degreaser should clean it up some.
Heat exchanger needs end plates and gaskets.
I'll need to take it apart to ascertain the amount of corrosion and/or damage it has sustained.
(Note: the hose w/ the elbow is not mine)
I'm lucky this belt didn't break while underway. I'll replace both sides.
These small flexible radiator hoses are OK but I need a set on the port side.
What you might call the business end of 6BTA
I want to touch up the paint some, how hard would a complete paint job be I wonder?
Need a couple vibration isolators. And an oil pan gasket.
Steve
Take a look at these pics..........Before and After.........The after pic still shows some primer touch up. In the end I will shoot the entire engine one more time. I had the engine completely disassembled so it was realitively easy to paint each component. I used BLP brand MoPoxy 2 part Epoxy primer and Mothane 2 part Urethane topcoat.
Is the extra pulley on the front of your engine just an idler or does it drive something???
- John Jackson
Randall
Sure is satisifying.......Cannot wait to see them sitting in a clean and painted engine room.
Steve
Another thought.......look real close to at your exhaust elbows, mine are stainless steel and I firmly believe that the one that I am showing you is the main cause of engine failure. Now is the perfect time to take a good look. I would take it off and bead blast it to get a good close up look.
Some of the exhaust elbows are Cuppr-Nickle and they last a lot longer....this may be the case with your elbows
Harry
Steve
Harry
Harry nice job I have one question?
The second picture has what looks to be sealer around the top edge of the oil pan. Is this correct because they seem to weep a little oil from the bolt holes is thst what I see? Did it work?
I also say do the rebuild on the pump not worth taking the chance you don't want to overheat them!
Dan
Dan
Dan
When I painted the engine I intentionally let the paint wrap around the gasket surfaces of the block and the oil pan. I painted each item before assembly. Equipment typically starts rusting in these areas. My engines had a good bit of rust on the block in the area where the oil pan bolts up.
Sooooooo what I did was, after the pan was bolted on I applied more of the BLP MoPoxy primer to the areas that concerned me. My thoughts are that if I can "Bridge" the gap between the block and the pan and "Plug" the open threaded pan screw holes from the top, with the paint, I can possibly delay the rust for a few more years...........that is if my paint does not crack and flake off due to the thickness. The MoPoxy is a thick primer to start with......its made for thick buildup.
Does it work???? I did the same thing to my 350 in the old Chaparall 5 years ago........so far its still good.
You better believe that I will rebuild the Seawater pumps. I have ordered and received the necessary pump parts from Seaboard Marine.
Thanks for the complements
Harry
Harry
- TailhookTom
Users browsing this forum: Google [Bot] and 86 guests
