New fuel system question
Would it be OK to put an outbord style fuel primer ball in the fuel line to fill the fuel filters after replacing them. engines are Cummins210Hp and fuel inlet size is only 3/8 in.
I have the same engines. Your input side of the Racors should have shut-off valves on them so there is no backflow or air intrusion. When you take off the top of the Racor, remove the filter, dump the bowl fuel and replace the filter, you now have an empty Racor which has to be manually filled right up to the top before the cap is reinstalled. At this point, you can reopen the input valve and you have retained an air-free fuel line. I'm afraid an outboard type bulb would need air to work or might otherwise allow air to get into your fuel line, which on a diesel is a problem. I had an almost invisible hairline crack on the bottom of one Racor bowl. It was so small it didn't leak. Yet if you came back to the boat after a few days away and started it, it would die after less than a minute of running. Then it took a LOT of cranking to get fuel up to the injectors again. Seems the prime got broken by the slow intrusion of air through the crack, and the fuel ran back to the tank. Once started, it didn't haoppen again all day, but the next time I came to the boat, it happened all over again. I changed EVERYTHING from the Racor to the injector pump in my attempt to correct it. It wasn't until my son was standing in front of the engine when I was cranking it and saw bubbles in the racor bowl that we discovered the culprit. Hence my concern for anything in the fuel line system that might let air in. One man's experience. Walter
I'm having battery problems in the tin foil hat and looking at alternative fuel sources to keep my carbon footprint down.
What power I do have has been interupted by the galactic alert messages comming in from Orions Belt over the "Unauthorized Biography of Tom Cruise".
This has some people very high up in the time/space continuum very upset.
Since the power loss has reduced my gamma wave Neptunal receptions that are continuously present during low voltage fast neocortical activity which are involved in higher mental activity, I have to keep my answers short till I develop new power sources.
I need to take a nap now.
- AndreF
I think this thread was highjacked. Against the rules................
Brings back memories....
Sean?
Sean?
1981 FBC BERG1883M81E
Prof, funny you mention the portable GPU, I been thinking the same thing now that I have time on my hands.......now is the season when the grosbeaks hatch out, so there are lots of little ones, so shrinking the design is a do-able thing. I'll put some time in on it and wiring it up to the tin foil hat should be a snap, maybe go wireless. We could put Hugo and the arabs out of the oil business with a little carry-around GPU.
UV,
Is that "do-able" or "do-do-able"???
Here's another possible power source:
National Geographic News
August 18, 2005
Before you next flush the toilet, consider this: Scientists in Singapore have developed a battery powered by urine.
Researchers at the Institute of Bioengineering and Nanotechnology created the credit card-size battery as a disposable power source for medical test kits.
Scientists have been scrambling to create smaller, more efficient, and less expensive "biochips" to test for diseases such as diabetes. Until now, however, similarly small batteries to power the devices remained elusive.
Diagnostic test kits commonly analyze the chemical composition of a person's urine to detect a malady. Ki Bang Lee and his colleagues realized that the substance being tested—urine—could also power the test.
"In order to address this problem, we have designed a disposable battery on a chip, which is activated by biofluids such as urine," Lee wrote in an e-mail to National Geographic News.
The research team describes the battery in the current issue of the Journal of Micromechanics and Microengineering.
Daniel Kammen, director of the Renewable and Appropriate Energy Laboratory at the University of California, Berkeley, said the technology is a welcome innovation in a time of rising energy prices.
"All jokes [about] urine aside, what is needed are low-cost batteries. …" he said. "The other neat thing about this is the fact that it's basically a biodegradable battery."
Urine Power
To make the battery, Lee and his colleagues soaked a piece of paper in a solution of copper chloride and sandwiched it between strips of magnesium and copper. This sandwich was then laminated between two sheets of transparent plastic.
When a drop of urine is added to the paper through a slit in the plastic, a chemical reaction takes place that produces electricity, Lee said.
The prototype battery produced about 1.5 volts, the same as a standard AA battery, and runs for about 90 minutes. Researchers said the power, voltage, and lifetime of the battery can be improved by adjusting the geometry and materials used.
August 18, 2005
Urine Power
- JohnCranston
Sounds like somone's pissin into the wind.CaptPatrick wrote:UV,
August 18, 2005
Urine Power
Harv
Drifter,
Even with the primer bulb, air in the system would have to be bled out.
The problem with the primer direct inline is that it has a check ball inside that one can become disloged and block fuel flow, two won't work at all and three will restrict fuel flow.
If you want a bulb for a priming system, install it as a bypass.
Filling the spin on is good, but knowing how to bleed out the system is essential for quick recoveries. Your not always going to be able to fill up a spin on at sea, with a primer bulb you'll need to crack the bleed and let the air out.
If your not sure how to plumb in as a bypass, if you could take a pic of your primary filter system and post, I'll tell you how.
Sorry for the thread hijack. I had a Timmy moment.
Thanks Bruce......I know how to plumb like a bypass with two tee's and three small ball valves. I read recently where Tony @ Sebold marine said on low flow engines he has been doing it in line and as a bypass fow 15yrs. Are you saying the check ball may fail due to crud in diesel fuel?
Also doesnt the primer bulb fill an outbord filter and system completly and displace the air in the filter assembly? If so why not on a diesel. Please bear with me on this since all i am used to is Racor"s
Drifter,
There are some mechanics who use primer bulbs inline on diesel.
I don't. My work is a reflection on me. Using anything but proper methods and materials is selling my customers short.
There is always a cheaper method for doing things. And many people choose that route.
The check ball doesn't fail from crud for the most part unless its installed pre primary filter, it just fails because its made of rubber and plastic and cost 5 bucks.
On an older OB, the air in the system will vent thru the carb. Gas goes into the bowl and the air in the lines vents out thru the jet venturi.
On injection, if enough air, you can air lock and not start. the high flow/high pressure pumps will on return systems pass air back to the tank. On closed circulation systems, too much air will lock it up and there is a tire valve wher you bleed it from in the system.
Some diesels will with an electric pump send the air back to the tank. Depends on the injection pump and return design on the injectors. Cummins is not one of those engines.
OK Bruce....One more question. I will plumb it in the bypass way right off the tank to fill a pair of spin on style filters. The filters are only 1ft from the tank.How should i vent the air? I know this is a basic stupid question but i am used to racors and spin ons are new to me.
I have racors and spin-on filters. The spin ons are right on the engine and come after the fuel runs through the racors. Once the fuel line is shut off before the racors, you can spin off, fill up the new ones and spin them on with no bleeding procedure at all. You have another set of spin-ons one foot off the tank? Walter
Users browsing this forum: No registered users and 83 guests
