Tef-gel amount?
Tef-gel amount?
I'm part way through my winter B31 window project. Got the fronts all taken apart, and I'll be replacing the T-bolts on the curved side windows with through-bolts. I'd like to use tef-gel when I reinstall--anybody have any idea how much I'll need? 1, 2, 3 tubes............? Thanks.
TefGel goes a long way... You only need a surface film between the dissimilar metals. For those 6 bolts only, a single small tube will still leave you with some material left over. But be smart & buy a large tube and you'll have plenty for years to come. Remember the old Brylcreem commercial?
"A little dab'll do ya'"
Sorry, wasn't thinking clearly... The large tube should get the job done for all. Pre-treat all of the bolts & nuts at the same time, rather than individually. That way you minimize your waste. While you still have the material on your fingers, rub on a little on each bolt hole, both sides of the frame. Clean up is done with mineral spirits...
Even with that many replacements Patrick is right. I bought the small jar (2 oz.) with a brush, and have Tef Gelled everything in sight and haven't used a quarter of it.
Users browsing this forum: Google [Bot], Stav and 48 guests
