Transmission service - sanity check
I'm having my stbd ZF tranny inspected and probably rebuilt. Here's the expected cost:
Pull engine and transmission: 2-3 hours @ $65/hr
Rebuilt transmission: $1000 - $2000
Heat exchanger if required $250
Replace all: 2-3 hours @ $65
(Engines need to be pulled to get transmission out, plus I'll be able to more easily sand/paint/replace belts and hoses/clean & paint bilge/etc)
So I'm looking at $2000 - $3000 total. I'm located in MD. It seems OK to me but I don't know any better. My relatives in the midwest are convinced I'm being ripped off but they're do-it-yourselfers w/ smaller boats and everything's cheaper over there.
B&H -- Boats and Harbors Magazine Also on net at http://www.boats-and-harbors.com/
Sounds like a decent deal to me. Down here you will not pay less than 110 per hour. the guy doing the work will not be giving you 110 dollars worth of knowledge or labor, then you will have to go back afterwards and fix the screw ups, ie, grease on the bolsters and the list goes on. Can't wait to re-locate.
Mine's a 28 w/ Cummins 210's. The transmissions are straddled by a doghouse in the bulkhead. He felt it would easier to just pull the engine than to try and fish it out of there. Plus I get great access for cleanup over the winter. (How often have I thought, "This would be easy if this damn thing were on a bench".)Raybo Marine NY wrote:we pulled Craig's transmissions out of his boat this spring to re-seal them, there was no need to remove the engine.
Steve
My thoughts are that if your transmission needs anything more than "Soft Parts" (seals, piston rings, gaskets and clutches) you will be better off puchasing a new transmission or a good running take out.
I think that 3 hours to pull and 3 more hours to install your engine may be underestimated.............I think a more realistic time estimate will be 3 or 4 to pull then 6 or 8 to do a complete and thorough install/alignment.
Ya know things never go as smooth as we expect.
$65 per hour is a great price.....I think the auto dealerships charge $75 per hour or so............I sent one of my outboard motors to the shop last summer to the tune of $87.00 per hour......OUCH
Harry
Harry
Shoot guys, I did not charge that much most of the time as a lawyer, now when I was a plumber, lots more.
There is a solution...learn to do it yourself....the Prince of Potions, His Honor from Galveston, has an airplane in additon to his Bertram. He got tired of paying big bucks to get a licensed airplane mechanic to change his oil and spark plugs, so he dove into it and got his A&P (airframe & powerplant) mechanic's license from the FAA, so he can maintain his own airplane, or that matter yours. I subscribe to His Honor's way to deal with our toys....learn how to work on your own stuff, get the basic tools and save a ton of money and misery. You can't fix it if you don't understand how it works tho, so spend some time in study.
I'm right there with you Vic..........You cannot put a price on the gratification of a job well done that you did yourself and the confidence that the job was done correctly.
The problem comes when you have more "Crap" to maintain than you have time maintain.............then you have to call for help. Thats when you better be able to trust your help
Harry
Harry
or you can do what i do.....theres not much chance i can rebuild an engine or a tranny...but i can unplug em from the boat and plug em back in....saves a good bit on the bill.....and you learn a lot.....i did every system on the austin healey like this including the engine...much cheaper than just taking it in and now i know how everything goes together..and its all professionally rebuilt
Like an engine. to rebuild it correctly it takes parts and labor.
If the gear box needs anything other than clutches and seals my experience has been to purchase a new or exchange for a rebuild from a factory rebuilder.
I don't do as many gears as before because it doesn't pay. I only deal with authorized rebuilders as they have the equipment to shop test the rebuild rather than install and then find out there is a problem.
Call Transmission Marine in Ft Lauderdale and quiz them on price for an exchange or new. They won't give a rebuild price until they see the gear.
954/467/1540.
Also bow down and thank the marine Gods for the 65/hr.
I'm on the low end of the hourly rate at 70/hr and it goes up to 150/hr.
Or like my friend who decided to save 125 bucks and trim his own tree.....
The chainsaw was 200.00, ladder was 150.00 and when he fell out of the tree and the saw landed on his arm and broke it, medical was over a thousand, so he spent 1400 bucks to save 125.
Must be the new math.
954/467/1540.
With the general group we have here. I whole heartily support your theory as we be a special group, and I don't mean the olymipcs.learn how to work on your own stuff, get the basic tools and save a ton of money and misery. You can't fix it if you don't understand how it works tho, so spend some time in study.
sometimes you just cant avoid getting screwed.....when my port tranny broke i did all the work necessary to pull the engine....the yard i was in at the time wouldn't let me use a friends front end loader so i used their fork lift...took 11 minutes to drop that puppy in my truck....detatched the tranny and had a friend rebuild it...parts 100 bucks.....then had it bench tested by a pro...a..ok.$125...took 26 minutes to drop the whole thing back in the boat.........bill from marina...$500...when i left soon after the owner said to me....."you're a nice guy but i dont want customers who pull and replace their own engines...i want customers who give me their credit cards and say...do what it takes"...in a nice public marina now
I agree with Vic for two reasons. If you do it yourself, you know what's in there and can diagnose and maintain yourself. If you get stuck doing it yourself at least now you are an informed consumer and can talk to the mechanics with some intelligence. You are less likely to get your hat handed to you and your credit card incinerated.
I bought the manual for my ZF 220A's ($70) and ma making my own "soft" repairs. Reading the manual and doing the work I now understand the innards and am saving huge $$$.
SteveZ-
Thought I would share my experience. The in & out time seems a little fast, I did mine myself, and was much longer than that. Granted my inexperince slowwed me down, but for me the big hassle was moving my holding tank hoses which were in the way. The working space was beyond tight slowing me down. Lots of things needed to be moved out of the way so I could extract the beast out of the little hatch ...remote oil filter....electrical cables.,,,,ect.
Don't unders estimate the time it takes for proper shaft alignment. It took my hours of trail and error to get it right. (I still plane to retweak the alignment again.) Can't for the life of me figure out why it was so far out after a remove and replace operation, but it was.
You should replace the damper plate....I went with one of the R & D "new age" rubberized units at about 300 because it was the only one I could find with the correct offset for my enging tranny combo. (Old cummins 504 to a 73C BorgWarner.) I think you can get a standard unit for around $100-$150.
All the best & Merry Christmas.
Giff
Giff
Giff
Users browsing this forum: Briancc, Google [Bot] and 81 guests
