December Fishing
December Fishing
So I pull out of the lagoon this afternoon to go Toggin, make the left get Chimera up on plane and the first thing I see comin down the bay is a B31 a friend of mines boat (Frank P's boat looking better than ever) get a phone call from another friend (Neil) B31 gives me a call with the update on Striper fishin. Get offshore to one of the local reefs run into Neil's other boat B25 fishin get the report and then the wind starts blowin (like 20 NW) just crappy enough not the set the hook.
Run up to North to 40ft of water (indside of the wind) set the hook on a little pile of rock and start catching the togs. First keeper on the boat caught by my son. Yeah team!!! Long story short, fish a short afternoon catch 9 keeper tog to 6lbs. Eat a nice warm fish chowder before pullin the hook (thanks Capt. Neil) and come home with fish for momma.
Doesn't get any better than this.
I'm always amazed it doesn't matter what time of year you'll always find a Bertram on the water and more then likely if your on this site you know the boat.
Rock on Bertram brothers, keep the lines wet!!!!!
i am going to the fire island reef 12/9 sunday my first attempt at black
fishing.i am using a 975 penn conventional reel and a light action chaos rod with braid.i with start with a hi/lo rig anything else i shoud know? like what is the best bait; hermit crabs,fidler crabs, squid or half a blue claw.
waterk,jp,brewster any other northern 31 brothers can you give me a little clue.-------------bob
- John Jackson
- John Jackson
Bob-we usually use green crabs because they're easy to get. Break off claws, cut in half, run hook through broken claw hole. Don't use a soft rod as setting the hook in their tough mouths is difficult. You have to set the hook as soon as you feel them. Lift hard at first as they'll dive into structure immediately and hang you up. If the crab half bait is in the water a while, it will be washed out so put on fresh. Hermit crabs are deemed to be the best, but almost impossible to find out east. If you do, they're very expensive. Using the new no-stretch lines is a good choice for Blackfish as they're very sensitive. I would however connect your sinker with a piece of weaker mono so as to have it break off if hung up in the rocky environment Blackfish live in. Good luck! Blackfish fillets make great eating! Don't cook them on the same day as you've caught them. Let the fillets "rest" in the fridge and cook them the next day. Seems the flesh needs to lose a bit of the moisture it holds and doesn't fall apart as it seems to do when heated too soon. Walter
Forget about the High Low Rig. Blackfish don't swim up for their food. Keep the hook or hooks at the same level as the sinker. High Low rigs are good for sea bass.
John is correct a med to stiff rod is best. You be using up to 6 ounces depending on conditions. And you could get a stud like 14lbs. You need to get the fishes head turned and coming to you before he can rock or wreck you.Remember you want to feel the bite. Set on the second thump. First thump they crush it second thump they eat it, then set and crank at the same time. If the burgals are around learn to fish through them they'll feel more like vibrations then bites.
Good Luck Tell me how many new cus words you learn.
speaking of blacks {fish that is }
last year fishing live bait in the inlet, thought i had a bump or got hung up on the mussle beds, lifted the rod and fish on, taking line hummm nice size bass iam saying.got him to the boat put the net down and what the f#@%^$ brought him in to the boat big black had to be 2' long, seems i snaged him in the belly, when i finnally got over the size of him i gave him a kiss on thos big rubber lips and sent her back home, also season was closed, damm
went to fi reef --nothing,then went to the san diego wreck, a heavy cruiser sunk by the germans in ww1.john jackson was right on the money just plain frustraing they take the green crabs and go back into the wreck so i could cut my line and slammed my fist against against the gunnels.i wish i had posted earlier then i could have taken jp`s advice on the high- low rig all i did was lose two crabs at the same time to bergalls!!! walterk i did read your post before leaving and changed to a stiffer rod.1 black fish for a all day affair two on the boat between 4 guys and the radio blasting bluefin here and bluefin jumping out of the water in front of the inlet in 65' of water!i am in a 28' parker that i just drove to the wreck at 55mph maybe i should i go back and get the phoenix and jump on those bluefin----nay we should stay and killed the togs-------------wrong move!!!!
Users browsing this forum: No registered users and 103 guests
