Repower has begun
Repower has begun
Just as planned I ran DeNada to Fly Creek in Fairhope to be loaded onto a trailer and brought to my shop for repower last Friday.
Checkout this guys trailer........the entire trip and off loading process was absolutely painless. As usual, with the proper equipment everything is easy.
She is now blocked and chocked and the destruction phase of repower is well underway.
Tonight the engines are out, the sister stringers have been removed,the entire engine compartment has been gutted and what was a good running boat just 3 days ago is now in total disarray and looks horrible.
[/img]
[/img]
Harry[/img]
[/img]
[/img]
Harry[/img]
Harry, When you're done love to see a picture like the first one, profile in the water, to see where your waterline is with the new engines. How much fuel was on board at the time of the pictures? Are you adding a larger tank?
Still trying to get a realistic sense of where my waterline will be.
Damn, that express is a fine looking profile.
My Express is a 1966 model and I think it holds about 175 gallons. If my estimate is correct she had about 100 gallon aboard when the picture was taken. I do know that when she is full of fuel the chine at the transom is just barely in the water.
No I am not going to install a larger tank on during this work session. I may add a couple of saddle tanks if I have the time.
My major goal right now is to repower, plug a dozen old unused holes in the bottom (from old transducers), strip and repaint the bottom, build a nice small tower and get back in the water this spring. Several friends have offered to help me but I still intend to keep the project to a managable size so as not to over tax my friends and still get back in the water this spring.
Harry
Harry
- Skipper Dick
Hey Harry...looks like you're off to a good start, at this pace you will be up & running by spring easy. You got to have that B31 running by Venice time next year.
DQ
DQ
"IN GOD WE TRUST"
"IN GOD WE TRUST"
Sim I like your top....... its size seems to match the boat size. I once built a top to fit my old Chaparral 244 that actually looks similar to your top.
I do not have all of the fine details yet but pretty much I am going to try to keep the front support legs inside of the windshield and the rear support legs will pass thru the gunnel and anchor to the hull down below somewhere. All of the vertical members will be at an angle nearly equal to the angle of the windshield...........pretty much everything will angle from the bow towards the stern.
Its to dad blame cold to work on DeNada tonight......north wind blowing and its going down into the upper 30's tonight.
Harry
Harry
Thanks UV and Harry.
Angle on the front of tower match the windshield fairly close. I wasn't so sure how stable the house top was when designing the tower so I opted to mount to gunnels. I also was not crazy how a tower looked directly over the windshield or in front of it. Mine is back several inches and I had the canvas windows follow the windshield line up to the tower. Also it was an easy way to eliminate running gauges up top as I just glance down and read the lower helm gauges and sync. Just a pair of idiot alarms for temp and oil pressure had to be run.
I would think mounting on the gunnels would be stronger then to the hull directly as the gunnels have those rolled over angles and contours giving strenght. The hull sides being large flat panels seem to have lots of flex. Or where you going to kick the mounts over and go into the bottom? Maybe I'm wrong, never really thought about it much.
Harry, the tower was probly the single best thing I ever did to the boat it really makes driving in sloppy seas a whole lots better. The only person I met that did not care for it was my 6'+ father in-law, tower is just 6' over the engine box's.
Sim
On my old Chaparral I mounted the rear feet on the gunnel. There was way to much flex on the gunnel. The width of the gunnel was much narrower than on the Bertram. On the Chaparral I had to add another brace (Hand Holder) that paralleled the rear leg and went all the way to the floor.
I am thinking of a foot that goes from the hull bottom to the underside of the gunnel with a flange and the rear support leg will sit on top of the gunnel with a matching flange and the two will be bolted together.
UV can always use me as an example when he refers to his quote "The Enemy of Good is Better" ..........I am generally known for over building things but the only thing I usually have to apologize for is weight and material cost.
Tonight I unbolted the shaft logs from the hull (unbolted with a grinder, hammer and punch) and got bogged down trying to remove the starboard coupling...........I gave her a good dose of CX and came home for supper.....tomorrow I am expecting to see the coupling laying on the floor when I get there LOL
Harry
Harry
Hopefully, when all is said and done with my repower, I would like to add a small tower on Windstar as well. As most of you know, Windstar is a Bahia Mar. I have looked at different designs and find that the nicest tower lines are the towers being used on the Luhrs, Henriques, and Albamarle expresses. Below is a picture of what Luhrs calls a "bridge tower". It has easy access and a bench seat for at least 2 people. I especially like the easy access with no bars to climb under.
Harv
Harv
That's a very good looking tower/top..........I've not seen one like that before.......is it made by Luhrs or is it by a custom builder in the area.
I particularly like the idea of not having to crouch down to go under bars or having to climb over bars........as you know in rolling seas you could get a goose egg on your head or be ripped of your manhood trying to get up or down.
I have taken pictures of DeNada and printed them on regular paper, from that I will be sketching my ideas...........I will be using the open bar feature for sure
Harry
Harry
Hummmmmmmmmm........never thought of that......excellent idea......can probably use small tube for a prototype......
Doug what is the pitch and dia of your DJX wheels?????
I am going to make a serious attempt of decreasing my shaft angle.....I think that all I need is 12-1/2" from shaft centerline to the hull bottom when measured square with the shaft in the prop location area.
Got a lot different projects on my mind right now.....this weekend I intend to dryfit the engines.........the Top/Tower project will come to life sometime in January
Harry
Harry
Harry,
3/4" is probaly about as small as you want to go with the pvc.
My DJX'S are 21" x 20" and your probaly going want to leasve that angle along. I took my tabs off and with the Cummins 250's you don't need them. My 31 trims out very nice.
Richard Kidd @ Bertram 20 years ago told me that 31's did not need them and really becomes personal choice, with the diesels and the 21" wheels I in total agreement.
DQ
DQ
"IN GOD WE TRUST"
"IN GOD WE TRUST"
Harry,
I originally saw this type of tower on the Luhrs expresses about 7 years ago. I beleive it was a standard design for them, as it was on each express from the 29 to the 40 footer. Last year at the Atlantic City show, I saw the same design on the Henriques express and the Albamarle express.....or was it a Rampage? In any case, I believe Luhrs had them first and the idea of the bars wrapping around the bench and the ease of accessability has caught on with other boat makers. It is a smart design for sure.
Harv
Skipper Dick
Is this waht you had in mind for a half tower for your B28?
<a href="http://photobucket.com" target="_blank"><img></a>
Bill
Bill
Bill,
If you want to post a picture click the img tab below the subject box so this appears [img]
After that copy the url address of the hosting page with the photo.
Photobucket usually has 4 boxes under the picture. I usually use the 2nd from top and that usually does the trick.
Photobucket is easy to use as it only needs 1 left click on the box and it tells you address copied when you do it.
Then click close tags and this will appear [/img]
When done it should look like this
[img]your%20image%20at%20wherever.com[/img]
Make sure there are no spaces between the tags.
And then the photo should be available for everyone to see.
I know I am curious how it looks.
If you still have trouble, email to me and I will post it for you.
Harv
- Skipper Dick
- Skipper Dick
Bill,
You got it and that's what I'm looking for except I'm not looking for one off the manufacturers floor, but something that has been in a wreck or salvage that I can remake or repair. I'm pretty good with glassing and finishing so that way I can get my own sweat equity in it. Besides, when ever I make something or repair a part of the hull, I always feel much better about it.
Nice looking vessel.
Dick
Dick
Dick,
There was a full tower sitting in Treasure Island Marina last time I was there. It came off a 31 Bahia Mar. It's a little worn looking but might be right up your alley if interested. If yes, I can call or pass by and see if it is still available. Only problem is logistics, as it is located in Long Island, NY.
Harv
- Skipper Dick
Harv,
Thanks for the info. What I'm thinking of doing is right after the holidays, I'll head on over to Fort Liquirdale and the East coast to a couple of salvage yards I've heard of and see if I can find one in a yard and get it before they chew it up. They still hae a number of places trying to get rid of hurricane damaged boats and parts there. Once I get it home I can make it new again.
Dick
Dick
Harv, Harry,
May be getting in this game a little late, but have been designing and installing the struts for the hardtop (same as tower). To get it to look right, and save money I did the whole thing in PVC. Once complete and taped in place I called the maker and he came, made notations, and cut and tacked the parts. I took them to the boat, installed them and he came back to check all out. He then returned them to his shop, completed the welding and I installed them. Looks great, installed perfectly the first time and since he wasn't making several round trips to the boat, I saved bunches.
PVC bends very easily with a heat gun and can be "welded" in place with PVC glue. Don't stress it a lot and it will hold.
Just a thought.
Just a thought.
Repower has begun
Harry,
I sent you a private message on shaft angles.
Good morning Mikey
Thanks for the suggestion.........sounds like a good idea to me......Doug made the same suggestion...........obviously PVC is cheaper and easier than metal
Yesterday I sat the Starboard engine in DeNada......just sitting on wood blocks........today I will remove the strut and get the shaft set where I want it......the bilge is still a mess...........for now I am in the Destroy and Dry Fit stage..........I will try to post pics tonight.
I intend to start my Top/Tower in February once I get everything under the hood buckled up..........its impossible to have someone working on the tower and in the cabin while repowering.
Tonight I will try to post pics of a tower that I built on my Chaparrel several years ago......
I am looking forward to seeing some pics of your Tower progress...........can you post them this evening?????
Gotta go beat on an old Bertram for now........thanks for the suggestion
Harry
Harry
Harry,
Some tips on shaft alignment & angle:
1 Leave the stock 15º shaft angle alone...
2 Remove the struts & remove any wedges or pads between the strut & hull
3 Decide if you want to change the strut angle slightly outboard to allow shafts to be removed without dropping rudders. (Relocation of Struts)
4 Re-install struts, without any wedges or pads. (Dry fit only at this point, but tighten them down fully.)
5 Align the engines & shafts to the struts, not vise versa.
While you have the struts down, that's the perfect time to deal with new inside backing plates as described in the Tips Section (Classic Bertram Strut Problem)
You'll also be upgrading to 1 1/2" shafts which will be a very close fit through the bronze shaft alleys, so it would also be a good time to re-configure to the fiberglass shaft tubes. (Building Fiberglass Shaft Logs)
And, while you're at it.... Keep in mind that your new air boxes will consume some of your height requirement necessary for an outboard mounted generator, so build in the new shelf to be absolutely as low to the hull bottom as possible.
And you thought it was just going to be a matter of swapping blocks... ;^))
These are pics of my old Chaparrel. I built the top in 1987.........its been thru hell in handbasket and held up well.
[img][img]http://i147.photobucket.com/albums/r289 ... P_3032.jpg[/img][/img]
[img][img]http://i147.photobucket.com/albums/r289 ... P_3038.jpg[/img]
Harry Babb
Harry Babb
Pat
Today I actually removed the strut, made a dummy coupling that bolts to the gear then inserted a shaft to use for roughing in the engine placement and alignment. I see more about how it all works now and I will not be changing the shaft angle..........in fact it looks to me like you cannot decrease the shaft angle and be able to put a 20" wheel under my 31.
Last Thursday I ordered the necessary tube from Lewis Marine that I need to glass in a new shaft log.
The strut had a pretty thick wedge between the flange and the hull.
Now I am focusing on the strut, once I get it worked out and the engine anchored down I will glass in the shaft tube and move on to the port side.
I have read, reread and read again all of the boat building tips related to my repower.........I will be sticking right to tried and proven methods that you have laid out for us
[/img]
Harry
[/img]
Harry
Users browsing this forum: No registered users and 248 guests
