How is the grabrail on the horizontal section of the bridge (above the windows -- stb, fwd, and port) removed? The bolts seem to have backing nuts, but I don't see access to them. I don't want to take it off (for painting) if I can't put it back together.
Thanks!
--Marshall
Flybridge Grabrail Removal
bridge grabrail
You remove the over heads in the head and galley overhead ,,,if you have a flybridge cruiser.,.,.,or if a sportfisherman ,,pull down the overheads and you will have access to the nuts and bolts ,,an easy take of and replacement after you do what it is you want to do
Removing the ceiling in the cabin gives me access to the grabrail on the vertical section. I removed a light fixture and can reach 1 back-up nut on the horizontal rail. I never relized this before, but the bridge is made in 2 sections. They must have assembled the grabrail prior to putting the 2 sections together. Bummer.
Marshal,
I see where you're coming from... You rail isn't on the vertical side face of the flybridge, but rather on the sides of the house top.
Other than the rectangular opening for the light fixture, there is no other access to that area of the house top. That leads me to think that the two extreme ends of your grab rails are possibly just held by standard screws rather than through bolts.
If the screws in the end sections don't screw out they may be just stripped. Try removing the one through bolt you can access through the light opening & then put a block of wood under the grab rail, at each end, and pry up on the rail. You may get lucky and have the screw strip out of the fiberglass.
I doubt seriously that Bertram would have pre-assembled the rail before fitting the house top to the inner shell...
Are you going to replace the rail in the same position?
Users browsing this forum: Bing [Bot], Google [Bot] and 175 guests
